[Geoserver-devel] [JIRA] (GEOS-8129) GetLegendGraphic fails if SCALE is greater than MaxScaleDenominator
Lorenzo Pini created an issue
GeoServer / BugGEOS-8129
Issue Type:
BugBug
Affects Versions:
2.10.4
Assignee:
Unassigned
Created:
08/May/17 2:27 PM
Environment:
Linux 64bit, Java Oracle 1.8.0, Tomcat 7, GeoServer 2.10-snapshot ( 70b43aa9e8d6d3f6576a73620a9dc5821febb2ad )
DuctusRenderingEngine
No JAI
Priority:
MediumMedium
Reporter:
Lorenzo Pini
If a style has a Rule with <MaxScaleDenominator> and no other rule to match scales over it, the GetLegendGraphic fails with an Exception when a greater scale is requested.
Example, all the rules in the style “poi” have <MaxScaleDenominator>32000</MaxScaleDenominator>
If the requested scale matches the limit, it gives you an image:
http://demo.geo-solutions.it/geoserver/wms?service=WMS&request=GetLegendGraphic&format=image%2Fpng&height=12&width=12&layer=tiger%3Apoi&style=&version=1.3.0&SLD_VERSION=1.1.0&SCALE=32000
Otherwise an Exception:
http://demo.geo-solutions.it/geoserver/wms?service=WMS&request=GetLegendGraphic&format=image%2Fpng&height=12&width=12&layer=tiger%3Apoi&style=&version=1.3.0&SLD_VERSION=1.1.0&SCALE=32001
&lt;ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://demo.geo-solutions.it:80/geoserver/schemas/wms/1.3.0/exceptions_1_3_0.xsd"&gt;
&lt;ServiceException&gt;
java.lang.IllegalArgumentException: Width (2) and height (0) must be &gt; 0 Width (2) and height (0) must be &gt; 0
&lt;/ServiceException&gt;
&lt;/ServiceExceptionReport&gt;
Logs the following:
2017-05-08 14:24:35,257 ERROR [geoserver.ows] -
	at java.awt.image.SampleModel.&lt;init&gt;(SampleModel.java:126)
	at java.awt.image.ComponentSampleModel.&lt;init&gt;(ComponentSampleModel.java:146)
	at java.awt.image.PixelInterleavedSampleModel.&lt;init&gt;(PixelInterleavedSampleModel.java:87)
	at java.awt.image.Raster.createInterleavedRaster(Raster.java:641)
	at java.awt.image.Raster.createInterleavedRaster(Raster.java:278)
	at java.awt.image.BufferedImage.&lt;init&gt;(BufferedImage.java:376)
	at org.geoserver.wms.map.ImageUtils.createImage(ImageUtils.java:119)
	at org.geoserver.wms.legendgraphic.LegendMerger.buildFinalVLegend(LegendMerger.java:575)
	at org.geoserver.wms.legendgraphic.LegendMerger.mergeLegends(LegendMerger.java:294)
	at org.geoserver.wms.legendgraphic.BufferedImageLegendGraphicBuilder.buildLegendGraphic(BufferedImageLegendGraphicBuilder.java:436)
	at org.geoserver.wms.legendgraphic.PNGLegendOutputFormat.produceLegendGraphic(PNGLegendOutputFormat.java:41)
	at org.geoserver.wms.legendgraphic.PNGLegendOutputFormat.produceLegendGraphic(PNGLegendOutputFormat.java:22)
	at org.geoserver.wms.GetLegendGraphic.run(GetLegendGraphic.java:49)
	at org.geoserver.wms.DefaultWebMapService.getLegendGraphic(DefaultWebMapService.java:349)
	at sun.reflect.GeneratedMethodAccessor502.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
	at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
	at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
	at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:33)
	at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
	at com.sun.proxy.$Proxy127.getLegendGraphic(Unknown Source)
	at sun.reflect.GeneratedMethodAccessor501.invoke(Unknown Source)
	at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:857)
	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:144)
	at org.geoserver.gwc.web.blob.SqliteMultipartFilter.doFilterInternal(SqliteMultipartFilter.java:20)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:94)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
	at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
	at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:200)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:307)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Maybe related to GEOS-5846 Open and GEOS-5710 Closed
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.929.2#100040-sha1:94c1764)
Atlassian logo
