Richard Duivenvoorde created an issue |
sld file lost when moving style from workspace to default workspace |
Issue Type: |
Affects Versions: |
2.11.0 |
Assignee: |
Unassigned |
Components: |
Configuration |
Created: |
10/May/17 9:42 AM |
Environment: |
Windows Server /Tomcat install of Geoserver 2.11.0 (dev server) and 2.10.2 (live server). |
Priority: |
Reporter: |
When moving a style from a named workspace to the default (empty) workspace, the xml is copied over, but the sld is not (it is removed form the workspace directory though)… So you loose the sld file / style Context: for some time we had a workspace in which we also had our styles. So when style is in workspace, both xml and sld file appear in But after having some problems with workspaces and styles we do not use the workspaces anymore for the styles. And I gradually move the styles back from the named workspace (say ‘foo’) to the default workspace by going into the webui for a style and change the ‘Workspace’-dropdown there from ‘foo’ to the first option, which is an empty label. To test:
Note that I check the directories for confirmation, but the issue is about pure using gui for configuration. In 2.10.x and earlier this has worked flawlessly. Because this is actually deleting a style sld, I think this is a pretty severe issue? |
This message was sent by Atlassian JIRA (v1000.929.2#100040-sha1:94c1764) |
