Torben Barsballe created an issue |
Cannot delete style in a workspace if it has the name of a default style |
Issue Type: |
Assignee: |
Unassigned |
Components: |
web |
Created: |
26/May/17 10:51 PM |
Priority: |
Reporter: |
If you try and delete a workspaced style that has the same name as one of the default styles (point, line, polygon, raster, generic), you get an error message in the UI. This should not be the case - only global default styles should be undeleteable. |
This message was sent by Atlassian JIRA (v1000.1010.0#100044-sha1:19dbb8d) |
