[Geoserver-devel] [JIRA] (GEOS-8158) WFSPPIO fails to remove MetaDataProperty attributes
Ian Turton created an issue
GeoServer / BugGEOS-8158
Issue Type:
BugBug
Affects Versions:
2.11.1
Assignee:
Ian Turton
Components:
WPS
Created:
30/May/17 5:55 PM
Fix Versions:
2.11.2
Priority:
MediumMedium
Reporter:
Ian Turton
If you load data from a WFS in a WPS and then try to write the results out as a Zipped Shapefile (and other formats) fail as the features still contain the MetaDataProperty attribute which is an object.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.1010.2#100044-sha1:0b22eb5)
Atlassian logo
