Sorin Dudui created an issue |
Issue Type: |
Affects Versions: |
2.11.0 |
Assignee: |
Unassigned |
Components: |
Configuration |
Created: |
07/Jun/17 12:13 PM |
Priority: |
Reporter: |
Hi, I try to modify the schema of an existing Postgres Layer. I try to set the parameter nillable of the gid field to false. For this I use the instruction at : http://docs.geoserver.org/stable/en/user/services/wfs/schemamapping.html I cannot get the new change even I restart/reload the Geoserver configuration. Thank you, |
This message was sent by Atlassian JIRA (v1000.1043.0#100046-sha1:ba52bbd) |
