Steve Ikeoka created an issue |
Issue Type: |
Affects Versions: |
2.10.1, 2.11.1 |
Assignee: |
Unassigned |
Components: |
JDBCConfig |
Created: |
29/Jun/17 10:30 PM |
Priority: |
Reporter: |
Deleting a single workspace either through the UI or REST in both GeoServer 2.10 and 2.11 when JDBC Configuration is enabled will return an error response even though the workspace is successfully deleted. If multiple workspaces are deleted at the same time through the UI, then the first workspace will be successfully deleted but it will throw an error that prevents the rest of the workspaces from being deleted. In both the UI and REST, the namespace will be removed before removing the workspace. |
Get JIRA notifications on your phone! Download the JIRA Cloud app here. |
This message was sent by Atlassian JIRA (v1000.1092.0#100053-sha1:6914530) |
