[Geoserver-devel] [JIRA] (GEOS-8206) WMS 1.3.0 Axis ordering for non-geographic coordinate systems
Carsten Klein created an issue
GeoServer / BugGEOS-8206
Issue Type:
BugBug
Assignee:
Unassigned
Components:
WMS
Created:
30/Jun/17 3:52 PM
Priority:
MediumMedium
Reporter:
Carsten Klein
As stated by the documentation under Services / Web Map Service (WMS) / Axis Ordering, GeoServer uses EPSG-defined latitude/Longitude axis ordering for geographic coordinate systems with WMS 1.3.0. However, WMS 1.3.0 also requires to honor axis ordering defined by the EPSG database for non-geographic coordinate systems.
The 1.3.0 version of the OpenGIS Web Map Service (WMS) Implementation Specification (Doc #06-042) describes this under 6.7.3.1 (paragraph 5): Coordinates shall be listed in the order defined by the CRS and shall be …
The example mentioned is the Uniform Coordinate System used in Finland (EPSG:2393), which is not geographic, has Northing, Easting axis order. See this on epsg.io. The same is true for many more non-geographic coordinate systems, like for good old Gauss-Krüger EPSG:31466 to EPSG:31469 or the new European ETRS89 systems.
Actually, GeoServer does not implement this for non-geographic coordinate systems, which must be considered a bug, since it prevents up-to-date WMS clients from using WMS 1.3.0.
Add Comment
Add Comment
Get JIRA notifications on your phone! Download the JIRA Cloud app here.
This message was sent by Atlassian JIRA (v1000.1092.1#100053-sha1:0458056)
Atlassian logo
