[Geoserver-devel] [JIRA] (GEOS-8219) GeoServer Logs page fails to load if log is missing
Gnafu created an issue
GeoServer / BugGEOS-8219
Issue Type:
BugBug
Affects Versions:
2.12-beta
Assignee:
Unassigned
Components:
UI
Created:
11/Jul/17 4:32 PM
Environment:
Amazon Linux AMI
Priority:
MediumMedium
Reporter:
Gnafu
If the geoserver.log is missing, the GeoServer Logs page gives the following message.
To reproduce:
  • turn off logging by setting log4j.rootLogger=OFF, stdout in a logging properties file
  • nuke the geoserver.log
  • load the GeoServer Logs page
org.apache.wicket.WicketRuntimeException: Exception in rendering component: [TextArea [Component id = logs]]
	at org.apache.wicket.Component.internalRenderComponent(Component.java:2625)
	at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1668)
	at org.apache.wicket.Component.internalRender(Component.java:2401)
	at org.apache.wicket.Component.render(Component.java:2329)
	at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1526)
	at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1729)
	at org.apache.wicket.Page.onRender(Page.java:879)
	at org.apache.wicket.markup.html.WebPage.onRender(WebPage.java:141)
	at org.apache.wicket.Page.renderPage(Page.java:1018)
	at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
	at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
	at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:157)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:85)
	at org.geoserver.params.extractor.Filter.doFilter(Filter.java:46)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
	at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:962)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:445)
	at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:190)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:316)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.RuntimeException: An error occurred while getting the model object for Component: [TextArea [Component id = logs, page = org.geoserver.web.admin.LogPage, path = logs, type = org.apache.wicket.markup.html.form.TextArea, isVisible = true, isVersioned = false, markup = [markup = jar:file:/var/lib/tomcats/geoserver/webapps/geoserver/WEB-INF/lib/gs-web-core-2.12-SNAPSHOT.jar!/org/geoserver/web/admin/LogPage.html
<textarea readonly="readonly" style="width:100%;height:50em;font-size:small" wicket:id="logs"></textarea>, index = 0, current =  '<textarea readonly="readonly" style="width:100%;height:50em;font-size:small" wicket:id="logs">' (line 0, column 0)]]]
	at org.apache.wicket.Component.getDefaultModelObject(Component.java:1651)
	at org.apache.wicket.Component.getDefaultModelObjectAsString(Component.java:1674)
	at org.apache.wicket.markup.html.form.FormComponent.getModelValue(FormComponent.java:1287)
	at org.apache.wicket.markup.html.form.FormComponent.getValue(FormComponent.java:871)
	at org.apache.wicket.markup.html.form.TextArea.onComponentTagBody(TextArea.java:67)
	at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:70)
	at org.apache.wicket.Component.internalRenderComponent(Component.java:2601)
	... 126 more
Caused by: org.apache.wicket.WicketRuntimeException: Cannot modify component hierarchy after render phase has started (page version cant change then anymore)
	at org.apache.wicket.Component.checkHierarchyChange(Component.java:3662)
	at org.apache.wicket.Component.addStateChange(Component.java:3577)
	at org.apache.wicket.Component.error(Component.java:1275)
	at org.geoserver.web.admin.LogPage$GSLogsModel.load(LogPage.java:151)
	at org.geoserver.web.admin.LogPage$GSLogsModel.load(LogPage.java:126)
	at org.apache.wicket.model.LoadableDetachableModel.getObject(LoadableDetachableModel.java:135)
	at org.apache.wicket.Component.getDefaultModelObject(Component.java:1646)
	... 132 more
Add Comment
Add Comment
Get JIRA notifications on your phone! Download the JIRA Cloud app here.
This message was sent by Atlassian JIRA (v1000.1112.0#100055-sha1:e34bbca)
Atlassian logo
