The error looks as follows:
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143)
at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:577)
at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:223)
at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1127)
at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:515)
at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185)
at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1061)
at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141)
at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:97)
at org.eclipse.jetty.server.Server.handle(Server.java:499)
at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:310)
at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:257)
at org.eclipse.jetty.io.AbstractConnection$2.run(AbstractConnection.java:540)
at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:635)
at org.eclipse.jetty.util.thread.QueuedThreadPool$3.run(QueuedThreadPool.java:555)
at java.lang.Thread.run(Thread.java:748)
Caused by: java.lang.IllegalArgumentException: SecureFeatureSources has been fed with unexpected AccessLimits class class org.geoserver.security.WorkspaceAccessLimits
at org.geoserver.security.decorators.SecuredFeatureSource.getReadQuery(SecuredFeatureSource.java:128)
at org.geoserver.security.decorators.SecuredFeatureSource.getFeatures(SecuredFeatureSource.java:83)
at org.geoserver.security.decorators.SecuredSimpleFeatureSource.getFeatures(SecuredSimpleFeatureSource.java:46)
at org.geotools.data.gen.PreGeneralizedFeatureSource.getFeatures(PreGeneralizedFeatureSource.java:222)
at org.geoserver.feature.retype.RetypingFeatureSource.getFeatures(RetypingFeatureSource.java:182)
at org.vfny.geoserver.global.GeoServerFeatureSource.getFeatures(GeoServerFeatureSource.java:459)
This happens because the pre-generalized store picks a DataStore via the Repository interface, and then grabs the feature sources out of it, instead of asking the Catalog directly like the rest of the code does.
The ReadOnlyDataStore in turn fails to build an appropriate policy type for the returned secured feature source, causing the error above.
