[Geoserver-devel] [JIRA] (GEOS-8276) imageio-ext-gdal-bindings-xxx.jar not available in geoserver-2.x.x-gdal-plugin.zip anymore since 2.10
Richard Duivenvoorde created an issue
GeoServer / BugGEOS-8276
Issue Type:
BugBug
Affects Versions:
2.10.0, 2.11.2
Assignee:
Unassigned
imageio-ext-gdal-bindings-1.9.2.jar
Components:
Global
Created:
07/Sep/17 11:09 AM
Environment:
All (though we are running on Windows Server)
Priority:
MediumMedium
Reporter:
As seen in title: imageio-ext-gdal-bindings-xxx.jar not available in geoserver-2.x.x-gdal-plugin.zip anymore since 2.10
We are using the gdal plugin to test ecw’s internally for some Geoserver versions.
Since 2.10 though the (apparently needed) imageio-ext-gdal-bindings-1.9.2.jar is NOT available anymore in the geoserver-2.x.x-gdal-plugin.zip…
The problem you will see is described here too:
http://osgeo-org.1560.x6.nabble.com/GeoServer-2-11-0-is-not-starting-after-installing-GDAL-plugin-Windows-Tomcat-td5315288.html
During startup you will see something like:
Failed to instantiate [org.geowebcache.io.ImageIOInitializer]: Factory method ‘getInstance’ threw exception; nested exception is java.util.ServiceConfigurationError: javax.imageio.spi.ImageReaderSpi: Provider it.geosolutions.imageio.plugins.arcbinarygrid.ArcBinaryGridImageReaderSpi could not be instantiated
In all my geoserver/plugin backups, the (attached) jar was available in the GDAL plugin zip till version 2.9.x
After 2.10.x it disappeared from the zip, giving rise to above problem.
As soon as you copy this jar to the lib dir of geoserver all is fine again.
Is this a packaging problem?
Or maybe a licensing problem?
This makes the upgrade process a little less smooth
Thanks for looking into this or providing any info.
Add Comment
Add Comment
Get JIRA notifications on your phone! Download the JIRA Cloud app for Android or iOS
This message was sent by Atlassian JIRA (v1000.1261.0#100059-sha1:3c555fd)
Atlassian logo
