[Geoserver-devel] [JIRA] (GEOS-8300) REST GET resource metadata - file extension can override format parameter
Torben Barsballe created an issue
GeoServer / BugGEOS-8300
Issue Type:
BugBug
Affects Versions:
2.12-beta
Assignee:
Unassigned
Components:
REST
Created:
25/Sep/17 11:42 PM
Priority:
MediumMedium
Reporter:
Torben Barsballe
If you make a REST GET request for resource metadata against a resource with a filename that includes an extension that is among the supported configuration formats (xml, html, json), then the filename of the resource will determine the content of the response rather than the format parameter.
For example, the request:
http://localhost:8080/geoserver/rest/resource/styles/point.xml?operation=METADATA&format=json
Will return metadata about the resource point.xml in XML format with content-type=application/json
However, the request
http://localhost:8080/geoserver/rest/resource/styles/point.sld?operation=METADATA&format=json
Will return metadata about the resource point.sld in JSON format, since sld is not a configuration format.
Add Comment
Add Comment
Get JIRA notifications on your phone! Download the JIRA Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100061-sha1:00abb8f)
Atlassian logo
