[Geoserver-devel] [JIRA] (GEOS-8302) Statatus monitoring community is failing with division by zeros
Nuno Oliveira created an issue
GeoServer / BugGEOS-8302
Issue Type:
BugBug
Assignee:
Nuno Oliveira
Components:
Community modules
Created:
26/Sep/17 3:33 PM
Fix Versions:
2.12-RC1
Priority:
MediumMedium
Reporter:
Nuno Oliveira
When computing usages percentages, if the total amount of an available resource (disk space, swap memory, etc …) is zero NaN will be produced.
The UI, HTML and XML output formats keep responding by showing NaN:
Unable to render embedded object: File (image-2017-09-26-14-33-06-787.png) not found.
JSON encoding fails. Instead of NaN zero should be used.
Add Comment
Add Comment
Get JIRA notifications on your phone! Download the JIRA Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100063-sha1:c0bd8e4)
Atlassian logo
