For tests, gs-sec-jdbc uses an ancient postgresql 8.4-701.jdbc3 jar that does not work with PostgreSQL 10. Tests fail in Maven. Tests pas in Eclipse only because the more recent 42.1.1 jar used everywhere else is a transitive dependency via gs-main in the Eclipse dependency model.
Tests in error:
testRoleDatabaseSetup(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testIsModified(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testInsert(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testModify(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testRemove(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testConfiguration(org.geoserver.security.jdbc.PostGisUserDetailsServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testRoleCalculation(org.geoserver.security.jdbc.PostGisUserDetailsServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testPersonalizedRoles(org.geoserver.security.jdbc.PostGisUserDetailsServiceTest): org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (This ResultSet is closed.)
testUserGroupDatabaseSetup(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testIsModified(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testPasswordRecoding(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testEraseCredentials(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testEmptyPassword(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testInsert(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testModify(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
testRemove(org.geoserver.security.jdbc.PostGisUserGroupServiceTest)
Solution is to upgrade the postgresql driver (and put it under dependency management to match GeoTools).
