Alessio Fabiani created an issue |
DataStoreFileController wrong management of FeatureTypes when dealing with DB-based DataStores |
Issue Type: |
Assignee: |
Unassigned |
Created: |
11/Oct/17 9:55 AM |
Priority: |
Reporter: |
Currently the DataStoreFileController is doing something weird. Basically it is possible to upload a zip file containing vectorial dataset to be added to a DB datastores. The DataStoreFileController blindly unzip it into a common folder named like the DB datastore. There is no way to cleanup this folder, since the check is done before the zip is uploaded. After that there are only two possibilities to configure the FeatureTypes:
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100063-sha1:08c88d8) |
