[Geoserver-devel] [JIRA] (GEOS-8347) MBStyle should create single NamedLayer when possible
Torben Barsballe created an issue
GeoServer / BugGEOS-8347
Issue Type:
BugBug
Assignee:
Unassigned
Created:
16/Oct/17 11:08 PM
Priority:
MediumMedium
Reporter:
Torben Barsballe
When an MBStyle is converted to SLD, it should create a single NamedLayer wherever possible.
MBStyle supports different source-layer}}s for each styled {{layer in the MBStyle. To support this in SLD, each layer is converted into its own NamedLayer, referencing the source-layer.
Whenever there is a block of layer elements with the same source-layer in an mbstyle, they should be merged as separate FeatureTypeStyles within a single NamedLayer. Order must still be preserved, so two layer}}s with the same {{source-layer that are separated by a layer with a different source-layer should not be merged.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100065-sha1:effcae0)
Atlassian logo
