When using Audit log endpoint /rest/monitor/* path, server will return only html representation:
$ curl -vv http://localhost:8080/geoserver/rest/monitor/requests/1.html
* Trying 127.0.0.1...
* TCP_NODELAY set
* Connected to localhost (127.0.0.1) port 8080 (#0)
> GET /geoserver/rest/monitor/requests/1.html HTTP/1.1
> Host: localhost:8080
> User-Agent: curl/7.54.0
> Accept: */*
< HTTP/1.1 200 OK
< Date: Tue, 17 Oct 2017 09:09:15 GMT
< Set-Cookie: JSESSIONID=node01f7eq6w2in071w4uxth17nqyf17.node0;Path=/geoserver
< Expires: Thu, 01 Jan 1970 00:00:00 GMT
< Content-Type: text/html
< Transfer-Encoding: chunked
< Server: Jetty(9.4.7.v20170914)
<html>
<head>
<style type="text/css">
General styles
body {
background: #fff;
.. (and rest of html)..
However, if XML or JSON representation will be requested, HTTP 406 will be returned:
$ curl -vv http://localhost:8080/geoserver/rest/monitor/requests/1.xml
* TCP_NODELAY set
> GET /geoserver/rest/monitor/requests/1.xml HTTP/1.1
> Accept: */*
< HTTP/1.1 406 Not Acceptable
< Date: Tue, 17 Oct 2017 09:12:46 GMT
< Set-Cookie: JSESSIONID=node01tw9ways7yvh11kylb04jwxwid18.node0;Path=/geoserver
< Content-Length: 0
* Connection #0 to host localhost left intact
$ curl -vv http://localhost:8080/geoserver/rest/monitor/requests/1.json
* TCP_NODELAY set
> GET /geoserver/rest/monitor/requests/1.json HTTP/1.1
> Accept: */*
< Date: Tue, 17 Oct 2017 09:12:48 GMT
< Set-Cookie: JSESSIONID=node01mo2swwbhe8jw1mt4nufoysrzy19.node0;Path=/geoserver
< Content-Length: 0
Tested with build with recent master
