[Geoserver-devel] [JIRA] (GEOS-8362) <encodeIfEmpty> fails on empty strings
Gavin Medley created an issue
GeoServer / BugGEOS-8362
Issue Type:
BugBug
Affects Versions:
2.12.0
Assignee:
Unassigned
Components:
Application schema
Created:
23/Oct/17 11:20 PM
Environment:
Ubuntu 16.04 LTS
Tomcat 7.0.26
openjdk version “1.8.0_111”
OpenJDK Runtime Environment (build 1.8.0_111-8u111-b14-3~12.04-b14)
OpenJDK 64-Bit Server VM (build 25.111-b14, mixed mode)
Geoserver 2.12.0
Application Schema Extension
PostGIS database
Priority:
MediumMedium
Reporter:
Gavin Medley
Elements are not encoded by App Schema when the database field is blank. Specifically, the problem arises when the field being mapped contains an empty string (‘’). i.e. it’s not a null value but it is empty so it doesn’t appear, even when I use &lt;encodeIfEmpty&gt;true&lt;/encodeIfEmpty&gt;
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100067-sha1:44753d7)
Atlassian logo
