[Geoserver-devel] [JIRA] (GEOS-8363) Creation of SQL View Layer with Parameters fails
Andreas Wagner created an issue
GeoServer / BugGEOS-8363
Issue Type:
BugBug
Affects Versions:
2.11.3, 2.12.0
Assignee:
Unassigned
Components:
Wicket UI
Created:
24/Oct/17 10:17 AM
Environment:
clean geoserver with test files included, no external data directory
added workspace & Postgis Datasource
Priority:
HighHigh
Reporter:
Andreas Wagner
Problem description
Starting with Geoserver 2.11.3 the options “Guess Parameters from SQL” and “Add new Parameter” in an SQL View are failing with an exception shown below.
Workflow to reproduce the issue:
  • clean Geoserver installation (War in Tomcat), no external data directory set
  • added new workspace (checked as default workspace)
  • added new POSTGIS DataSource
  • create SQL View
  • click “Add new Parameter” or define SQL with %PARAMNAME% Placeholder and click “Guess Parameters from SQL”
Sidenotes
  • Same Workflow works in versions before 2.11.3.
  • Once the view is created (e.g. use an older version of Geoserver to create the view and the upgrade geoserver) it can be rendered by the afflicted versions. So it seams its just a problem during creation in the UI.
Exception
org.apache.wicket.WicketRuntimeException: Exception in rendering component: [WebMarkupContainer [Component id = selectItemContainer]]
	at org.apache.wicket.Component.internalRenderComponent(Component.java:2625)
	at org.apache.wicket.MarkupContainer.onRender(MarkupContainer.java:1668)
	at org.apache.wicket.Component.internalRender(Component.java:2401)
	at org.apache.wicket.Component.render(Component.java:2329)
	at org.apache.wicket.MarkupContainer.renderNext(MarkupContainer.java:1526)
	at org.apache.wicket.MarkupContainer.renderAll(MarkupContainer.java:1729)
	at org.apache.wicket.MarkupContainer.renderComponentTagBody(MarkupContainer.java:1704)
	at org.apache.wicket.MarkupContainer.onComponentTagBody(MarkupContainer.java:1659)
	at org.apache.wicket.markup.html.panel.DefaultMarkupSourcingStrategy.onComponentTagBody(DefaultMarkupSourcingStrategy.java:70)
	at org.apache.wicket.Component.internalRenderComponent(Component.java:2601)
	at org.apache.wicket.markup.repeater.AbstractRepeater.renderChild(AbstractRepeater.java:115)
	at org.apache.wicket.markup.repeater.AbstractRepeater.onRender(AbstractRepeater.java:102)
	at org.apache.wicket.MarkupContainer.renderAssociatedMarkup(MarkupContainer.java:799)
	at org.apache.wicket.markup.html.panel.AssociatedMarkupSourcingStrategy.renderAssociatedMarkup(AssociatedMarkupSourcingStrategy.java:77)
	at org.apache.wicket.markup.html.panel.PanelMarkupSourcingStrategy.onComponentTagBody(PanelMarkupSourcingStrategy.java:112)
	at org.apache.wicket.page.XmlPartialPageUpdate.writeComponent(XmlPartialPageUpdate.java:119)
	at org.apache.wicket.page.PartialPageUpdate.writeComponents(PartialPageUpdate.java:248)
	at org.apache.wicket.page.PartialPageUpdate.writeTo(PartialPageUpdate.java:161)
	at org.apache.wicket.ajax.AjaxRequestHandler.respond(AjaxRequestHandler.java:358)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:97)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doPost(WicketServlet.java:159)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:661)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:742)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:158)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
	at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:870)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:231)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:166)
	at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:193)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:88)
	at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:199)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:96)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:478)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:140)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:81)
	at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:650)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:87)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:342)
	at org.apache.coyote.http11.Http11Processor.service(Http11Processor.java:803)
	at org.apache.coyote.AbstractProcessorLight.process(AbstractProcessorLight.java:66)
	at org.apache.coyote.AbstractProtocol$ConnectionHandler.process(AbstractProtocol.java:868)
	at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1459)
	at org.apache.tomcat.util.net.SocketProcessorBase.run(SocketProcessorBase.java:49)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.RuntimeException: An error occurred while getting the model object for Component: [CheckBox [Component id = selectItem, page = org.geoserver.web.data.layer.SQLViewNewPage, path = form:parameters:listContainer:items:1:selectItemContainer:selectItem, type = org.apache.wicket.markup.html.form.CheckBox, isVisible = true, isVersioned = false, markup = [markup = jar:file:/development/servers/graphium-apache-tomcat-8.5.23/webapps/geoserver/WEB-INF/lib/gs-web-core-2.11.3.jar!/org/geoserver/web/wicket/GeoServerTablePanel.html
<input type="checkbox" wicket:id="selectItem"/>, index = 0, current =  '<input type="checkbox" wicket:id="selectItem"/>' (line 0, column 0)]]]
	at org.apache.wicket.Component.getDefaultModelObject(Component.java:1651)
	at org.apache.wicket.Component.getDefaultModelObjectAsString(Component.java:1674)
	at org.apache.wicket.markup.html.form.FormComponent.getModelValue(FormComponent.java:1287)
	at org.apache.wicket.markup.html.form.FormComponent.getValue(FormComponent.java:871)
	at org.apache.wicket.markup.html.form.CheckBox.onComponentTag(CheckBox.java:144)
	at org.apache.wicket.Component.internalRenderComponent(Component.java:2542)
	... 151 more
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
	at org.geoserver.web.wicket.GeoServerTablePanel$SelectionModel.getObject(GeoServerTablePanel.java:698)
	at org.geoserver.web.wicket.GeoServerTablePanel$SelectionModel.getObject(GeoServerTablePanel.java:689)
	at org.apache.wicket.Component.getDefaultModelObject(Component.java:1646)
	... 165 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100068-sha1:c698fc2)
Atlassian logo
