[Geoserver-devel] [JIRA] (GEOS-8386) failed get DescribeFeatureType request when exists uuid field and DataStore option Expose primary keys set true
alexandr bobrov created an issue
GeoServer / BugGEOS-8386
Issue Type:
BugBug
Affects Versions:
2.11.1
Assignee:
Unassigned
ddl.and.data.sample.sql
Components:
WFS
Created:
10/Nov/17 5:29 PM
Environment:
windows 10 pro, postgresql 9.5, postgis 2.2.2, geoserver 2.11.1
Priority:
MediumMedium
Reporter:
alexandr bobrov
Hi!
I trying to create layer with uuid identifier.
I have already configured postgis sql datastore with existing layers.
And i create table in this database and register layer with default geoservser sld called ‘points’.
When I trying to exec request DescribeFeatureType I recive nothing.
request link sample
Answer:
<xsd:schema elementFormDefault="qualified" targetNamespace="gisbis"><xsd:import namespace="http://www.opengis.net/gml" schemaLocation="http://127.0.0.1:8083/geoserver/schemas/gml/3.1.1/base/gml.xsd"/></xsd:schema>
and such error in geoserver log
Unable to find source-code formatter for language: log. Available languages are: actionscript, ada, applescript, bash, c, c#, c++, cpp, css, erlang, go, groovy, haskell, html, java, javascript, js, json, lua, none, nyan, objc, perl, php, python, r, rainbow, ruby, scala, sh, sql, swift, visualbasic, xml, yaml
INFO   | jvm 1    | 2017/11/10 19:18:43 | 10 ноя 19:18:43 INFO [geoserver.wfs] -
INFO   | jvm 1    | 2017/11/10 19:18:43 | Request: getServiceInfo
INFO   | jvm 1    | 2017/11/10 19:18:43 | Request: describeFeatureType
INFO   | jvm 1    | 2017/11/10 19:18:43 |     service = WFS
INFO   | jvm 1    | 2017/11/10 19:18:43 |     version = 1.1.0
INFO   | jvm 1    | 2017/11/10 19:18:43 |     baseUrl = http://127.0.0.1:8083/geoserver/
INFO   | jvm 1    | 2017/11/10 19:18:43 |     typeName[0] = {te}sssss
INFO   | jvm 1    | 2017/11/10 19:18:43 |     outputFormat = text/xml; subtype=gml/3.1.1
INFO   | jvm 1    | 2017/11/10 19:18:43 | 10 ноя 19:18:43 WARN [geoserver.wfs] - Could not build xml schema for type: sssss
INFO   | jvm 1    | 2017/11/10 19:18:43 | java.lang.NullPointerException: Could not find a type for property: id of type: java.util.UUID
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.buildComplexSchemaContent(FeatureTypeSchemaBuilder.java:771)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.buildSchemaContent(FeatureTypeSchemaBuilder.java:691)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.buildSchemaInternal(FeatureTypeSchemaBuilder.java:260)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:154)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:148)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.FeatureTypeSchemaBuilder.build(FeatureTypeSchemaBuilder.java:137)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.v1_1_0.XmlSchemaEncoder.doWrite(XmlSchemaEncoder.java:107)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.xml.v1_1_0.XmlSchemaEncoder.write(XmlSchemaEncoder.java:96)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.wfs.WFSDescribeFeatureTypeOutputFormat.write(WFSDescribeFeatureTypeOutputFormat.java:80)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.ows.Dispatcher.response(Dispatcher.java:1009)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
INFO   | jvm 1    | 2017/11/10 19:18:43 | 	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
But when I set Expose primary keys in datastore options to false it state normally.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100070-sha1:a53fe37)
Atlassian logo
