https://build.geoserver.org/job/geoserver-master-app-schema-online/986/consoleText
Running org.geoserver.test.onlineTest.ComplexMongoDBLegacyTest
Tests run: 2, Failures: 1, Errors: 0, Skipped: 1, Time elapsed: 4.687 sec <<< FAILURE!
testGetStationFeaturesWithFilter(org.geoserver.test.onlineTest.ComplexMongoDBLegacyTest) Time elapsed: 1358 sec <<< FAILURE!
java.lang.AssertionError:
Expected: is <true>
but: was <false>
at org.hamcrest.MatcherAssert.assertThat(MatcherAssert.java:20)
at org.junit.Assert.assertThat(Assert.java:865)
at org.junit.Assert.assertThat(Assert.java:832)
at org.geoserver.test.onlineTest.ComplexMongoDBSupport.checkResult(ComplexMongoDBSupport.java:269)
at org.geoserver.test.onlineTest.ComplexMongoDBSupport.testGetStationFeaturesWithFilter(ComplexMongoDBSupport.java:133)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
Running org.geoserver.test.onlineTest.ComplexMongoDBTest
Tests run: 3, Failures: 1, Errors: 1, Skipped: 1, Time elapsed: 0.447 sec <<< FAILURE!
testGetStationFeaturesWithFilter(org.geoserver.test.onlineTest.ComplexMongoDBTest) Time elapsed: 53 sec <<< FAILURE!
Expected: is <true>
but: was <false>
org.geoserver.test.onlineTest.ComplexMongoDBTest Time elapsed: 67 sec <<< ERROR!
java.lang.IllegalArgumentException: /mnt/memtmp/app-schema-mongo783767322554067221 does not appear to be a directory at all...
at org.geoserver.util.IOUtils.emptyDirectory(IOUtils.java:262)
at org.geoserver.util.IOUtils.delete(IOUtils.java:247)
at org.geoserver.test.onlineTest.ComplexMongoDBSupport.tearDown(ComplexMongoDBSupport.java:76)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:33)
Results :
Failed tests: testGetStationFeaturesWithFilter(org.geoserver.test.onlineTest.ComplexMongoDBLegacyTest): (..)
testGetStationFeaturesWithFilter(org.geoserver.test.onlineTest.ComplexMongoDBTest): (..)
Tests in error:
org.geoserver.test.onlineTest.ComplexMongoDBTest: /mnt/memtmp/app-schema-mongo783767322554067221 does not appear to be a directory at all...
Tests run: 5, Failures: 2, Errors: 1, Skipped: 2
