Alessio Fabiani created an issue |
Issue Type: |
Assignee: |
Components: |
Main |
Created: |
21/Nov/17 5:51 PM |
Priority: |
Reporter: |
Forcing GZIPResponseStream to throw an Exception when flushing if the stream is closed can cause, wrongly, unwanted exceptions. https://github.com/geoserver/geoserver/blob/master/src/main/src/main/java/org/geoserver/filters/GZIPResponse The check above should instead just avoid flushing again if the stream is already closed {{ public void flush() throws IOException { { gzipstream.flush(); } }}} This happens especially on servlet filter chains. Very often it happens that a filter closes the stream. Since this is the last one called if the content-type can be compressed, it is highly probable that this will end throwing a wrong Exception. To reproduce the error, as an instance, just try to recall the “Importer” plugin REST Endpoint from cUrl instead of a Browser. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100072-sha1:a7bb548) |
