[Geoserver-devel] [JIRA] (GEOS-8472) Intermittent build failure in gs-main ResourcePoolTest tear down
Ben Caradoc-Davies created an issue
GeoServer / BugGEOS-8472
Issue Type:
BugBug
Affects Versions:
2.13-beta
Assignee:
Unassigned
Components:
Main
Created:
05/Dec/17 9:29 PM
Priority:
MediumMedium
Reporter:
Ben Caradoc-Davies
Seen locally and on Jenkins, ResourcePoolTest tear down occasionally fails when it is unable to delete its temporary data directory, almost certainly because it is not empty, likely because an H2 thread has not finished shutting down and has written a file between directory content deletion and directory deletion:
https://build.geoserver.org/job/geoserver-master/5355/consoleText
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 3.3 sec <<< FAILURE!
org.geoserver.catalog.ResourcePoolTest  Time elapsed: 93 sec  <<< ERROR!
java.lang.RuntimeException: java.io.IOException: Unable to delete directory ./target/default6742965833692039099data.
	at org.geoserver.test.GeoServerBaseTestSupport$1.apply(GeoServerBaseTestSupport.java:109)
	at org.junit.rules.RunRules.applyAll(RunRules.java:26)
	at org.junit.rules.RunRules.<init>(RunRules.java:15)
	at org.junit.runners.BlockJUnit4ClassRunner.withTestRules(BlockJUnit4ClassRunner.java:379)
	at org.junit.runners.BlockJUnit4ClassRunner.withRules(BlockJUnit4ClassRunner.java:340)
	at org.junit.runners.BlockJUnit4ClassRunner.methodBlock(BlockJUnit4ClassRunner.java:256)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:498)
Caused by: java.io.IOException: Unable to delete directory ./target/default6742965833692039099data.
	at org.apache.commons.io.FileUtils.deleteDirectory(FileUtils.java:1337)
	at org.geoserver.data.test.SystemTestData.tearDown(SystemTestData.java:1026)
	at org.geoserver.test.GeoServerBaseTestSupport.doTearDownClass(GeoServerBaseTestSupport.java:206)
	at org.geoserver.test.GeoServerBaseTestSupport$1.apply(GeoServerBaseTestSupport.java:107)
	... 27 more
This could be fixed by forcing synchronous shutdown of H2 if such a mechanism exists, or by a short Thread.sleep before recursive directory removal. The latter could be applied to all GeoServer tests.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100074-sha1:43f7724)
Atlassian logo
