[Geoserver-devel] [JIRA] (GEOS-8483) WPSResourceManager does not clean resourceCache in asynchronous process
miskender created an issue
GeoServer / BugGEOS-8483
Issue Type:
BugBug
Affects Versions:
2.12.1
Assignee:
Unassigned
Created:
11/Dec/17 10:19 AM
Priority:
MediumMedium
Reporter:
miskender
For synchronous process, finished executionId is removed from the resourceCache at
https://github.com/geoserver/geoserver/blob/7076e763387f0f682d05959e5b2d10442be12cf2/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/resource/WPSResourceManager.java#L321
But executionId’s of asynchronous process does not removed from the resourceCache,
Possible Fix:
https://github.com/geoserver/geoserver/blob/7076e763387f0f682d05959e5b2d10442be12cf2/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/resource/WPSResourceManager.java#L419
cleanExpiredResources can be modified like;
if (status == null || status.getPhase().isExecutionCompleted()) {
if( cleanupResource(r, expirationThreshold))
{ resourceCache.remove(r.name()); }
İf process’es output folder completely cleaned, It’s execution id can be removed from the resourceCache.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100074-sha1:3da8cec)
Atlassian logo
