[Geoserver-devel] [JIRA] (GEOS-8484) WPSResourceManager does not remove process root output folder
miskender created an issue
GeoServer / BugGEOS-8484
Issue Type:
BugBug
Affects Versions:
2.12.1
Assignee:
Unassigned
Created:
11/Dec/17 10:29 AM
Priority:
LowLow
Reporter:
miskender
Process with executionId = “xxxxx-xxxx-xxxx-xxxx” creates output folder with the same name. After execution of the process completes everything inside base folder is deleted but the base folder itself is not deleted. (This is tested with asynchronous process)
Possible Fix: WPSResourceManager.cleanupResource() method modified as;
else if (resourceType == Type.DIRECTORY) {
long folderModifiedBackUp = resource.lastmodified();
for (Resource child : resource.list())
{ result &= cleanupResource(child, expirationThreshold); }
if( folderModifiedBackUp < expirationThreshold)
{ result &= resource.delete(); }
else
{ result = false; }
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100074-sha1:3da8cec)
Atlassian logo
