[Geoserver-devel] [JIRA] (GEOS-8487) BruteForceListener issue with IpAddressMatcher
Mateusz Kacprzak created an issue
GeoServer / BugGEOS-8487
Issue Type:
BugBug
Affects Versions:
2.12.1
Assignee:
Unassigned
Components:
Security
Created:
12/Dec/17 1:10 PM
Priority:
MediumMedium
Reporter:
Mateusz Kacprzak
There is a little issue with doing actions that uses Geoserver catalog.
I.e.
When you authenticate with some user in code like this
securityContext.setAuthentication(authentication);
and attempt to call method from catalog like getFeatureTypeByName which is checked by GeoFence before execution you will get NullPointerException in BruteForceListener.
java.lang.NullPointerException
	at org.springframework.security.web.util.matcher.IpAddressMatcher.matches(IpAddressMatcher.java:47)
	at org.geoserver.security.BruteForceListener.lambda$requestAddressInWhiteList$0(BruteForceListener.java:122)
	at java.util.stream.MatchOps$1MatchSink.accept(MatchOps.java:90)
	at java.util.ArrayList$ArrayListSpliterator.tryAdvance(ArrayList.java:1351)
	at java.util.stream.ReferencePipeline.forEachWithCancel(ReferencePipeline.java:126)
	at java.util.stream.AbstractPipeline.copyIntoWithCancel(AbstractPipeline.java:498)
	at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:485)
	at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:471)
	at java.util.stream.MatchOps$MatchOp.evaluateSequential(MatchOps.java:230)
	at java.util.stream.MatchOps$MatchOp.evaluateSequential(MatchOps.java:196)
	at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234)
	at java.util.stream.ReferencePipeline.anyMatch(ReferencePipeline.java:449)
	at org.geoserver.security.BruteForceListener.requestAddressInWhiteList(BruteForceListener.java:122)
	at org.geoserver.security.BruteForceListener.onApplicationEvent(BruteForceListener.java:66)
	at org.geoserver.security.BruteForceListener.onApplicationEvent(BruteForceListener.java:30)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.invokeListener(SimpleApplicationEventMulticaster.java:167)
	at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:139)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:383)
	at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:337)
	at org.springframework.security.authentication.DefaultAuthenticationEventPublisher.publishAuthenticationSuccess(DefaultAuthenticationEventPublisher.java:84)
	at org.springframework.security.authentication.ProviderManager.authenticate(ProviderManager.java:213)
	at org.geoserver.security.GeoServerSecurityManager$1.authenticate(GeoServerSecurityManager.java:323)
	at org.geoserver.wps.gs.LuceneScheduler.setAuthentication(LuceneScheduler.java:58)
	at org.geoserver.wps.gs.LuceneScheduler.indexAllData(LuceneScheduler.java:37)
	at sun.reflect.GeneratedMethodAccessor1123.invoke(Unknown Source)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.springframework.scheduling.support.ScheduledMethodRunnable.run(ScheduledMethodRunnable.java:65)
	at org.springframework.scheduling.support.DelegatingErrorHandlingRunnable.run(DelegatingErrorHandlingRunnable.java:54)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
	at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
This exception is throwed because in fact you don’t send request but BruteForceListener catch it like request.
To fix it you need to do simple check in BruteForceListener
Here is completed code that works
 private boolean requestAddressInWhiteList(HttpServletRequest request,
            BruteForcePreventionConfig config) {
        // is there a white list?
        if (config.getWhitelistAddressMatchers() == null) {
            return false;
       if(request==null)
        	return true;
        return config.getWhitelistAddressMatchers().stream()
                .anyMatch(matcher -> matcher.matches(request));
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100074-sha1:e1ada01)
Atlassian logo
