[Geoserver-devel] [JIRA] (GEOS-8507) Make it possible to run XML related tests in IDE when both GeoTools and GeoServer sources are loaded
Andrea Aime created an issue
GeoServer / ImprovementGEOS-8507
Issue Type:
ImprovementImprovement
Assignee:
Unassigned
Created:
23/Dec/17 8:15 PM
Priority:
MediumMedium
Reporter:
Andrea Aime
If GeoTools sources are linked into the GeoServer classpath (happens with IntelliJ and Eclipse with Maven support, when both projects are loaded in the IDE) various tests fail because the entity resolver does not allow local file system resolution (happens in most tests doing schema validation, for example).
Rather than allowing full fledged entity resolution during tests (which would require reworking the entity resolution tests) make a special exception for the well known GeoTools schema locations while running tests.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100075-sha1:3f29be8)
Atlassian logo
