Idan Miara created an issue |
KML/KMZ Broken: export swapped east/west. import in QGIS is invalid. |
Issue Type: |
Affects Versions: |
2.12-RC1, 2.11.4 |
Assignee: |
Unassigned |
Attachments: |
wms.kml, wms1.kml, wms2.kml |
Created: |
22/Jan/18 5:40 PM |
Priority: |
Reporter: |
(This is a Follow up for a Geoserver-devel thread that I created. Brad & Andrea, thanks for your help) I’m trying to get a KMZ (KML compressed) file from Geoserver (2.12.1 or Master) and load it in QGIS (2.18.x or Master). The problem can be reproduced with a fresh Geoserver platform independent zip installation (Master or 2.12.1, same results) as follows: Layer Preview-> nurc:Img_Sample -> Select KML (compressed) Please note in this KML file: if you open this KML/KMZ in Google Earth Pro it works just fine even tough this error. Open this KML in QGIS (2.18.x or Master, same results) you will get a blank square instead of the raster. fixing wms.kml to load in QGIS: edit wms.kml as follows: edit wms1.kml as follows: Note that all 3 files load correctly in Google Earth Pro. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100076-sha1:948d923) |
