Stefan Müller created an issue |
GeoServer >=2.11 not starting with SecurityManager on Tomcat |
Issue Type: |
Affects Versions: |
2.11.0, 2.12.1 |
Assignee: |
Unassigned |
Components: |
Main |
Created: |
25/Jan/18 11:43 AM |
Environment: |
Tomcat 8.0 |
Priority: |
Reporter: |
startup fails, when SecurityManager is enabled SecurityManager permission is given via {catalina.base} /-", “read,write,delete”; Exception on startup: When starting the first time with an geoserver.war without an datadir, geoserver starts normal, creates the default datadir with an default content. But after an restart - then datadir is already here - geoserver will not come up again with the mentioned message. |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100077-sha1:43add18) |
