Giancarlo Bruno Honores created an issue |
Issue Type: |
Affects Versions: |
2.12.2 |
Assignee: |
Unassigned |
Components: |
Configuration |
Created: |
21/Feb/18 7:02 PM |
Environment: |
OS: Centos 7 |
Priority: |
Reporter: |
Good morning, i was installing JAI and JAI Image, follow the documentation from Geoserver, the JAI work ok, without problems, but when i install JAI Image with the commands: _$ sudo cp jai_imageio-1_1-lib-linux-i586-jdk.bin /usr/lib/jvm/java-6-sun
the install is correct, but when i start Geoserver, it show the error message: I can’t access to Geoserver, i have to re install Java, the Geoser working correctly. Please i need fix it. Thank you |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100080-sha1:8dde0bb) |
