[Geoserver-devel] [JIRA] (GEOS-8620) using rest api to create spacial directory results in a shapfile store instead of directory of spacial files
bas created an issue
GeoServer / BugGEOS-8620
Issue Type:
BugBug
Affects Versions:
2.12.2
Assignee:
Unassigned
Components:
REST
Created:
07/Mar/18 10:39 AM
Priority:
MediumMedium
Reporter:
bas
When i create a Directory of spatial files (shapefiles) store, using the website it works fine (although browsing still has bugs trough symlinks), but i manage.
When i then get the store using the rest api i can fetch the .xml file containing it’s definition
i get something like this:
<dataStore>
<name>myShapefiles</name>
<type>Directory of spatial files (shapefiles)</type>
<connectionParameters>
<entry key=“memory mapped buffer”>false</entry>
<entry key=“timezone”>Europe/Amsterdam</entry>
<entry key=“create spatial index”>true</entry>
<entry key=“charset”>ISO-8859-1</entry>
<entry key=“filetype”>shapefile</entry>
<entry key=“cache and reuse memory maps”>true</entry>
<entry key=“url”>file:/path/to/shapefiles/myShapefiles/</entry>
</connectionParameters>
</dataStore>
When i save that xml, remove the datastore using the website and then add it again using the rest api, it doesn’t create a ‘Directory of spatial files (shapefiles)’ but a ‘shapefile’
It all functions (i can create layers etc.), but it displays the wrong properties in the website and i can’t edit it anymore (i get wrong dialogs)
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100081-sha1:75480ba)
Atlassian logo
