Joerg Roth created an issue |
Issue Type: |
Affects Versions: |
2.11.5, 2.12.1, 2.12.2, 2.13-beta |
Assignee: |
Unassigned |
Components: |
CSW |
Created: |
08/Mar/18 12:36 PM |
Environment: |
Linux Ubuntu 16.04 amd64 with tomcat 8.0.32, Geoserver as war. |
Priority: |
Reporter: |
If one enables CSW in a workspace (e.g. test) and fills out the form, an almost correct csw.xml will be created in the data/workspace/test/ but with the same <name></name>-tag as the csw.xml in the data-root (e.g. ‘My GeoServer CSW’). Restarting geoserver throws an error in the log: Failed to load the service configuration in directory: /var/lib/tomcat8/apps/geoserver-2.11.5/data/workspaces/test with loader for interface org.geoserver.csw.CSWInfo When one stops tomcat and changes the <name></name>-tag of the workspace-csw.xml to a valid name, geoserver starts, does not complain, but CSW is not enabled in the workspace even when the workspace-csw.xml shows <enabled>true</enabled>. The csw-getCapabilites-request shows the information of the data-root-csw.xml and the data-root-global.xml in both requests (root and workspace). |
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS |
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100081-sha1:75480ba) |
