For example, removing the NetCDF extension causes the following:
Caused by: com.thoughtworks.xstream.mapper.CannotResolveClassException: netCDFSettings
at com.thoughtworks.xstream.mapper.DefaultMapper.realClass(DefaultMapper.java:81)
at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:125)
at com.thoughtworks.xstream.mapper.DynamicProxyMapper.realClass(DynamicProxyMapper.java:55)
at com.thoughtworks.xstream.mapper.PackageAliasingMapper.realClass(PackageAliasingMapper.java:88)
at com.thoughtworks.xstream.mapper.ClassAliasingMapper.realClass(ClassAliasingMapper.java:79)
at com.thoughtworks.xstream.mapper.ArrayMapper.realClass(ArrayMapper.java:74)
at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:71)
at org.geoserver.config.util.SecureXStream$DetailedSecurityExceptionWrapper.realClass(SecureXStream.java:150)
at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47)
at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29)
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:72)
at com.thoughtworks.xstream.converters.collections.MapConverter.putCurrentEntryIntoMap(MapConverter.java:110)
at com.thoughtworks.xstream.converters.collections.MapConverter.populateMap(MapConverter.java:98)
at com.thoughtworks.xstream.converters.collections.MapConverter.populateMap(MapConverter.java:92)
at com.thoughtworks.xstream.converters.collections.MapConverter.unmarshal(MapConverter.java:87)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72)
It would be nice if the metadata map would catch these exceptions and log them, instead of preventing startup.
I am aware there is a similar issue with WPS and removed process plugins, however that one might be similar rather than same, and require a different solution
