In the context of the correct virtual service, WPS aggregate process requires the type name to be prefixed with the workspace name.
This issue can be reproduced with the topp:states layers using the following request:
<?xml version="1.0" encoding="UTF-8"?><wps:Execute version="1.0.0" service="WPS" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.opengis.net/wps/1.0.0" xmlns:wfs="http://www.opengis.net/wfs" xmlns:wps="http://www.opengis.net/wps/1.0.0" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">
<ows:Identifier>gs:Aggregate</ows:Identifier>
<wps:DataInputs>
<wps:Input>
<ows:Identifier>features</ows:Identifier>
<wps:Reference mimeType="text/xml" xlink:href="http://geoserver/wfs" method="POST">
<wps:Body>
<wfs:GetFeature service="WFS" version="1.0.0" outputFormat="GML2" xmlns:sf="http://www.openplans.org/spearfish">
<wfs:Query typeName="states"/>
</wfs:GetFeature>
</wps:Body>
</wps:Reference>
</wps:Input>
<wps:Input>
<ows:Identifier>aggregationAttribute</ows:Identifier>
<wps:Data>
<wps:LiteralData>PERSONS</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<ows:Identifier>function</ows:Identifier>
<wps:Data>
<wps:LiteralData>Count</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
<wps:LiteralData>Average</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
<wps:LiteralData>Sum</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
<wps:LiteralData>Min</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<wps:Data>
<wps:LiteralData>Max</wps:LiteralData>
</wps:Data>
</wps:Input>
<wps:Input>
<ows:Identifier>singlePass</ows:Identifier>
<wps:Data>
<wps:LiteralData>false</wps:LiteralData>
</wps:Data>
</wps:Input>
</wps:DataInputs>
<wps:ResponseForm>
<wps:RawDataOutput mimeType="application/json">
<ows:Identifier>result</ows:Identifier>
</wps:RawDataOutput>
</wps:ResponseForm>
</wps:Execute>
Targeting topp virtual service:
http://<host>:<port>/geoserver/topp/wps
This request will fail with the following exception:
org.geoserver.wps.WPSException: Failed to retrieve value for input features
at org.geoserver.wps.executor.LazyInputMap.parseInputs(LazyInputMap.java:94)
at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:50)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:659)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:544)
at org.geoserver.wps.executor.ProcessStartupFilter$ProcessStartupWrapper.execute(ProcessStartupFilter.java:51)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:201)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:169)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.geoserver.wfs.WFSException: Could not locate {http://www.opengis.net/wfs}states in catalog.
at org.geoserver.wfs.GetFeature.featureTypeInfo(GetFeature.java:1256)
at org.geoserver.wfs.GetFeature.run(GetFeature.java:396)
at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:122)
at org.geoserver.wps.executor.InternalWFSInputProvider.getValueInternal(InternalWFSInputProvider.java:48)
at org.geoserver.wps.executor.AbstractInputProvider.getValue(AbstractInputProvider.java:97)
at org.geoserver.wps.executor.LazyInputMap.parseInputs(LazyInputMap.java:86)
... 10 more
