[Geoserver-devel] [JIRA] (GEOS-8659) Adding space around graphic fills
alinemaria created an issue
GeoServer / BugGEOS-8659
Issue Type:
BugBug
Affects Versions:
2.12.1
Assignee:
Unassigned
Components:
Documentation, WMS
Created:
22/Mar/18 4:07 PM
Priority:
LowLow
Reporter:
alinemaria
Olá!!
Estou usando a versão 2.12.1 do geoserver e o tópico da documentação ‘Adding space around graphic fills’ permite o uso do <VendorOption name=“graphic-margin”>10</VendorOption> para espaçar os símbolos usados para estilizar com o ‘graphic fills’. (http://docs.geoserver.org/2.12.1/user/styling/sld/extensions/margins.html)
Mas quando insiro a informação no sld, o erro abaixo é exibido (ver print).
Foi detectado um conteúdo inválido começando com o elemento ‘VendorOption’. Era esperado um dos ‘{“http://www.opengis.net/sld”:Stroke}’.
O que pode estar errado?
Segue dois exemplos de .sld com problema.
<?xml version=“1.0” encoding=“ISO-8859-1” standalone=“yes”?>
<sld:StyledLayerDescriptor version=“1.0.0” xmlns:sld=“http://www.opengis.net/sld” xmlns:ogc=“http://www.opengis.net/ogc” xmlns:xlink=“http://www.w3.org/1999/xlink” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” xsi:schemaLocation=“http://www.opengis.net/sld ./Sld/StyledLayerDescriptor.xsd”>
<sld:NamedLayer>
<sld:Name>Default</sld:Name>
<sld:UserStyle>
<sld:Title>Default</sld:Title>
<sld:FeatureTypeStyle>
<sld:Rule>
<sld:Name>Polygon</sld:Name>
<sld:Title>Polygon</sld:Title>
<sld:PolygonSymbolizer>
<sld:Fill>
<sld:GraphicFill>
<sld:Graphic>
<sld:ExternalGraphic>
<sld:OnlineResource xmlns:xlink=“http://www.w3.org/1999/xlink” xlink:type=“simple” xlink:href=“./rockFillSymbol.png”/>
<sld:Format>image/png</sld:Format>
</sld:ExternalGraphic>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
</sld:PolygonSymbolizer>
</sld:Rule>
</sld:FeatureTypeStyle>
</sld:UserStyle>
</sld:NamedLayer>
</sld:StyledLayerDescriptor>
<sld:NamedLayer>
<sld:UserStyle>
<sld:Rule>
<sld:Fill>
<sld:CssParameter name=“fill”>#AACBAF</sld:CssParameter>
</sld:Fill>
<sld:Stroke>
<sld:CssParameter name=“stroke”>#91A995</sld:CssParameter>
</sld:Stroke>
<sld:Fill>
<sld:GraphicFill>
<sld:Graphic>
<sld:OnlineResource xmlns:xlink=“http://www.w3.org/1999/xlink” xlink:type=“simple” xlink:href=“ICONES/Cemiterio_0.png”/>
<sld:Size>15</sld:Size>
</sld:Graphic>
</sld:GraphicFill>
</sld:Fill>
</sld:Rule>
</sld:UserStyle>
</sld:NamedLayer>
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100082-sha1:91c8a36)
Atlassian logo
