[Geoserver-devel] [JIRA] (GEOS-8661) GeoServer 2.12.x with plugins fails to show layer previews
Gnafu created an issue
GeoServer / BugGEOS-8661
Issue Type:
BugBug
Affects Versions:
2.12.3
Assignee:
Unassigned
Components:
Backup and Restore, Control-flow, CSS, CSW, GeoFence, geopackage, Image Pyramid, Mapfish print, Monitoring, OGR output format, Querylayer, WPS
Created:
26/Mar/18 12:37 PM
Priority:
MediumMedium
Reporter:
Gnafu
I have a GeoServer 2.12.x with the following plugins:
geoserver-2.12-SNAPSHOT-csw-plugin.zip
geoserver-2.12-SNAPSHOT-monitor-plugin.zip
geoserver-2.12-SNAPSHOT-printing-plugin.zip
geoserver-2.12-SNAPSHOT-querylayer-plugin.zip
geoserver-2.12-SNAPSHOT-wps-plugin.zip
geoserver-2.12-SNAPSHOT-ogr-wfs-plugin.zip
geoserver-2.12-SNAPSHOT-css-plugin.zip
geoserver-2.12-SNAPSHOT-control-flow-plugin.zip
geoserver-2.12-SNAPSHOT-pyramid-plugin.zip
geoserver-2.12-SNAPSHOT-gdal-plugin.zip
geoserver-2.12-SNAPSHOT-status-monitoring-plugin.zip
geoserver-2.12-SNAPSHOT-geofence-server-plugin.zip
geoserver-2.12-SNAPSHOT-gwc-sqlite-plugin.zip
geoserver-2.12-SNAPSHOT-geopkg-plugin.zip
geoserver-2.12-SNAPSHOT-backup-restore-plugin.zip
and the imageio-ext-gdal-bindings-1.9.2.jar
It was working fine up to commit https://github.com/geoserver/geoserver/commit/6a9676b4b6d04dc0d65446f4b491be5681df4977
After that, the layer preview page stopped working, and all the CSW requests started to fail.
This is the wicket stack trace:
org.apache.wicket.WicketRuntimeException: Error attaching this container for rendering: [WebMarkupContainer [Component id = listContainer]]
	at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1848)
	at org.apache.wicket.Component.onBeforeRender(Component.java:3916)
	at org.apache.wicket.Component.internalBeforeRender(Component.java:950)
	at org.apache.wicket.Component.beforeRender(Component.java:1018)
	at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1836)
	at org.apache.wicket.Page.onBeforeRender(Page.java:801)
	at org.apache.wicket.Component.internalPrepareForRender(Component.java:2236)
	at org.apache.wicket.Page.internalPrepareForRender(Page.java:242)
	at org.apache.wicket.Component.render(Component.java:2325)
	at org.apache.wicket.Page.renderPage(Page.java:1018)
	at org.apache.wicket.request.handler.render.WebPageRenderer.renderPage(WebPageRenderer.java:124)
	at org.apache.wicket.request.handler.render.WebPageRenderer.respond(WebPageRenderer.java:236)
	at org.apache.wicket.core.request.handler.RenderPageRequestHandler.respond(RenderPageRequestHandler.java:175)
	at org.apache.wicket.request.cycle.RequestCycle$HandlerExecutor.respond(RequestCycle.java:895)
	at org.apache.wicket.request.RequestHandlerStack.execute(RequestHandlerStack.java:64)
	at org.apache.wicket.request.cycle.RequestCycle.execute(RequestCycle.java:265)
	at org.apache.wicket.request.cycle.RequestCycle.processRequest(RequestCycle.java:222)
	at org.apache.wicket.request.cycle.RequestCycle.processRequestAndDetach(RequestCycle.java:293)
	at org.apache.wicket.protocol.http.WicketFilter.processRequestCycle(WicketFilter.java:261)
	at org.apache.wicket.protocol.http.WicketFilter.processRequest(WicketFilter.java:203)
	at org.apache.wicket.protocol.http.WicketServlet.doGet(WicketServlet.java:137)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:621)
	at javax.servlet.http.HttpServlet.service(HttpServlet.java:722)
	at org.springframework.web.servlet.mvc.ServletWrappingController.handleRequestInternal(ServletWrappingController.java:157)
	at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:174)
	at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
	at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:963)
	at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:897)
	at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:970)
	at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:861)
	at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:846)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
	at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
	at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
	at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:243)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
	at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
	at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
	at org.geoserver.monitor.MonitorFilter.doFilter(MonitorFilter.java:85)
	at org.geoserver.gwc.web.blob.SqliteMultipartFilter.doFilterInternal(SqliteMultipartFilter.java:20)
	at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
	at org.geoserver.flow.controller.IpBlacklistFilter.doFilter(IpBlacklistFilter.java:94)
	at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
	at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
	at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
	at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
	at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
	at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
	at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
	at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
	at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:205)
	at org.geoserver.security.filter.GeoServerUserNamePasswordAuthenticationFilter.doFilter(GeoServerUserNamePasswordAuthenticationFilter.java:116)
	at org.springframework.security.web.authentication.rememberme.RememberMeAuthenticationFilter.doFilter(RememberMeAuthenticationFilter.java:157)
	at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
	at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
	at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
	at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
	at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
	at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
	at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
	at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:88)
	at org.geoserver.filters.XFrameOptionsFilter.doFilter(XFrameOptionsFilter.java:89)
	at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
	at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
	at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
	at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:197)
	at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:224)
	at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:169)
	at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:472)
	at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:168)
	at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:98)
	at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:927)
	at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
	at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
	at org.apache.coyote.ajp.AjpProcessor.process(AjpProcessor.java:200)
	at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:579)
	at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:307)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.IllegalArgumentException: Could not find a security wrapper for class class com.sun.proxy.$Proxy93, cannot secure the object
	at org.geoserver.security.decorators.SecuredObjects.secure(SecuredObjects.java:65)
	at org.geoserver.security.decorators.SecuredLayerInfo.getResource(SecuredLayerInfo.java:40)
	at org.geoserver.catalog.impl.AdvertisedCatalog.hideLayer(AdvertisedCatalog.java:94)
	at org.geoserver.catalog.impl.AdvertisedCatalog.checkAccess(AdvertisedCatalog.java:148)
	at org.geoserver.catalog.impl.AbstractFilteredCatalog.checkAccess(AbstractFilteredCatalog.java:398)
	at org.geoserver.catalog.impl.AbstractFilteredCatalog$1.apply(AbstractFilteredCatalog.java:851)
	at org.geoserver.catalog.impl.AbstractFilteredCatalog$1.apply(AbstractFilteredCatalog.java:847)
	at com.google.common.collect.Iterators$8.transform(Iterators.java:794)
	at com.google.common.collect.TransformedIterator.next(TransformedIterator.java:48)
	at org.geoserver.catalog.util.CloseableIteratorAdapter.next(CloseableIteratorAdapter.java:57)
	at com.google.common.collect.Iterators.addAll(Iterators.java:357)
	at com.google.common.collect.Lists.newArrayList(Lists.java:147)
	at org.geoserver.web.demo.PreviewLayerProvider.iterator(PreviewLayerProvider.java:169)
	at org.apache.wicket.markup.repeater.data.DataViewBase$ModelIterator.<init>(DataViewBase.java:107)
	at org.apache.wicket.markup.repeater.data.DataViewBase.getItemModels(DataViewBase.java:74)
	at org.apache.wicket.markup.repeater.AbstractPageableView.getItemModels(AbstractPageableView.java:101)
	at org.apache.wicket.markup.repeater.RefreshingView.onPopulate(RefreshingView.java:93)
	at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:124)
	at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:115)
	... 131 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100082-sha1:c94a2a9)
Atlassian logo
