[Geoserver-devel] [JIRA] (GEOS-8668) 2.14 WPS DownloadMap fails with more than one layer input
Gnafu created an issue
GeoServer / BugGEOS-8668
Issue Type:
BugBug
Affects Versions:
2.14-beta
Assignee:
Unassigned
Components:
Community modules, WPS
Created:
30/Mar/18 10:59 AM
Priority:
MediumMedium
Reporter:
Gnafu
This issue appears to be only in the 2.14.x (the release 2.13.0 works correctly)
To reproduce:
  • Download the platform independent binary for 2.14.x
  • Add WPS plugin
  • Add WPS Download community module
  • Issue the following WPS request:
<wps:Execute version="1.0.0" service="WPS"
             xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns="http://www.opengis.net/wps/1.0.0"
             xmlns:wfs="http://www.opengis.net/wfs" xmlns:wps="http://www.opengis.net/wps/1.0.0"
             xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml"
             xmlns:ogc="http://www.opengis.net/ogc" xmlns:wcs="http://www.opengis.net/wcs/1.1.1"
             xmlns:xlink="http://www.w3.org/1999/xlink"
             xsi:schemaLocation="http://www.opengis.net/wps/1.0.0 http://schemas.opengis.net/wps/1.0.0/wpsAll.xsd">
  <ows:Identifier>gs:DownloadMap</ows:Identifier>
  <wps:DataInputs>
    <wps:Input>
      <ows:Identifier>bbox</ows:Identifier>
      <wps:Data>
        <wps:BoundingBoxData crs="EPSG:4326">
          <ows:LowerCorner>-55.11469223386748 -1.175069167133131</ows:LowerCorner>
          <ows:UpperCorner>67.14116714113253 72.65305583286687</ows:UpperCorner>
        </wps:BoundingBoxData>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <ows:Identifier>width</ows:Identifier>
      <wps:Data>
        <wps:LiteralData>1024</wps:LiteralData>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <ows:Identifier>height</ows:Identifier>
      <wps:Data>
        <wps:LiteralData>618</wps:LiteralData>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <ows:Identifier>layer</ows:Identifier>
      <wps:Data>
        <wps:ComplexData xmlns:dwn="http://geoserver.org/wps/download">
          <dwn:Layer>
            <dwn:Name>tiger:poi</dwn:Name>
          </dwn:Layer>
        </wps:ComplexData>
      </wps:Data>
    </wps:Input>
    <wps:Input>
      <wps:Data>
          <dwn:Layer>
            <dwn:Name>tiger:giant_polygon</dwn:Name>
          </dwn:Layer>
        </wps:ComplexData>
      </wps:Data>
    </wps:Input>
   </wps:DataInputs>
  <wps:ResponseForm>
    <wps:RawDataOutput mimeType="image/jpeg">
      <ows:Identifier>result</ows:Identifier>
    </wps:RawDataOutput>
  </wps:ResponseForm>
</wps:Execute>
The request will fail with the following error:
<wps:ProcessFailed>
            <ows:ExceptionReport version="1.1.0">
                <ows:Exception exceptionCode="NoApplicableCode">
                    <ows:ExceptionText>Failed to retrieve value for input layerIl prefisso "dwn" per l'elemento "dwn:Layer" non è associato.</ows:ExceptionText>
                </ows:Exception>
            </ows:ExceptionReport>
        </wps:ProcessFailed>
In the console there is the following log:
2018-03-30 10:54:08,138 ERROR [wps.executor] - Process execution failed
org.geoserver.wps.WPSException: Failed to retrieve value for input layer
	at org.geoserver.wps.executor.LazyInputMap.parseInputs(LazyInputMap.java:94)
	at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:50)
	at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:659)
	at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:544)
	at org.geoserver.wps.executor.ProcessStartupFilter$ProcessStartupWrapper.execute(ProcessStartupFilter.java:51)
	at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:201)
	at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:169)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
	at java.lang.Thread.run(Thread.java:748)
Caused by: javax.xml.bind.UnmarshalException
 - with linked exception:
[org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 12; Il prefisso "dwn" per l'elemento "dwn:Layer" non è associato.]
	at javax.xml.bind.helpers.AbstractUnmarshallerImpl.createUnmarshalException(AbstractUnmarshallerImpl.java:335)
	at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.createUnmarshalException(UnmarshallerImpl.java:563)
	at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:249)
	at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal(UnmarshallerImpl.java:214)
	at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:140)
	at javax.xml.bind.helpers.AbstractUnmarshallerImpl.unmarshal(AbstractUnmarshallerImpl.java:123)
	at org.geoserver.wps.gs.download.JaxbPPIO.decode(JaxbPPIO.java:57)
	at org.geoserver.wps.gs.download.JaxbPPIO.decode(JaxbPPIO.java:37)
	at org.geoserver.wps.executor.SimpleInputProvider.getValueInternal(SimpleInputProvider.java:84)
	at org.geoserver.wps.executor.AbstractInputProvider.getValue(AbstractInputProvider.java:97)
	at org.geoserver.wps.executor.ListInputProvider.getValue(ListInputProvider.java:61)
	at org.geoserver.wps.executor.LazyInputMap.parseInputs(LazyInputMap.java:86)
	... 10 more
Caused by: org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 12; Il prefisso "dwn" per l'elemento "dwn:Layer" non è associato.
	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.createSAXParseException(ErrorHandlerWrapper.java:203)
	at com.sun.org.apache.xerces.internal.util.ErrorHandlerWrapper.fatalError(ErrorHandlerWrapper.java:177)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:400)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:327)
	at com.sun.org.apache.xerces.internal.impl.XMLErrorReporter.reportError(XMLErrorReporter.java:284)
	at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.scanStartElement(XMLNSDocumentScannerImpl.java:284)
	at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl$NSContentDriver.scanRootElementHook(XMLNSDocumentScannerImpl.java:613)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:3132)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(XMLDocumentScannerImpl.java:852)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:602)
	at com.sun.org.apache.xerces.internal.impl.XMLNSDocumentScannerImpl.next(XMLNSDocumentScannerImpl.java:112)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:505)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:842)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:771)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:141)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1213)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:643)
	at com.sun.xml.internal.bind.v2.runtime.unmarshaller.UnmarshallerImpl.unmarshal0(UnmarshallerImpl.java:243)
	... 19 more
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100082-sha1:2fc2d84)
Atlassian logo
