[Geoserver-devel] [JIRA] (GEOS-8684) PUT to datasources with method option as `external` not working has expected
Abel Soares created an issue
GeoServer / BugGEOS-8684
PUT to datasources with method option as external not working has expected
Issue Type:
BugBug
Affects Versions:
2.13.0
Assignee:
Unassigned
Components:
REST
Created:
14/Apr/18 4:47 PM
Environment:
mac os, running Geoserver 2.13 compiled from source.
Priority:
MediumMedium
Reporter:
Abel Soares
Following the REST API documentation [here][1] i should be able to do a PUT request to `/workspaces/
{workspaceName}
/datastores/
{storeName}
{method}
{format}
. Problem is i cannot get how to do it with an external` method option.
This is with i’m doing:
I already have a .zip file with shapefiles in the geoserver data directory and i do the following PUT:
/workspaces/MyWorkspace/datastores/StoreName/external.shp
The file absolute path is in the body and the myWorkspace already exists.
Geoserver logs:
org.geoserver.rest.RestException 500 INTERNAL_SERVER_ERROR: Error while storing uploaded file:
Caused by: java.net.MalformedURLException: no protocol: "/Users/Projects/geoserver/data/release/myData/shapefile.zip"
It really seems to me that Geoserver is trying to process the file path as an url but that should only happen if method was url.
Also, i’m able to do this request with success if method is file and the body has the file binary.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100082-sha1:f003f73)
Atlassian logo
