[Geoserver-devel] [JIRA] (GEOS-8738) gs-app-schema-postgis-test build fails in PagingTest
Ben Caradoc-Davies created an issue
GeoServer / BugGEOS-8738
Issue Type:
BugBug
Affects Versions:
2.14-beta
Assignee:
Unassigned
Components:
Application schema
Created:
10/May/18 2:27 PM
Environment:
postgresql-10 10.3-2
postgresql-10-postgis-2.4 2.4.4+dfsg-1 amd64
Priority:
MediumMedium
Reporter:
Ben Caradoc-Davies
gs-app-schema-postgis-test fails in PagingTest locally and on Jenkins:
Failed tests:   testGetFeatureWithFilter(org.geoserver.test.PagingTest): expected:<1> but was:<3>
Running org.geoserver.test.PagingTest
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.806 sec <<< FAILURE!
testGetFeatureWithFilter(org.geoserver.test.PagingTest)  Time elapsed: 1103 sec  <<< FAILURE!
java.lang.AssertionError: expected:<1> but was:<3>
	at org.junit.Assert.fail(Assert.java:88)
	at org.junit.Assert.failNotEquals(Assert.java:743)
	at org.junit.Assert.assertEquals(Assert.java:118)
	at org.junit.Assert.assertEquals(Assert.java:555)
	at org.junit.Assert.assertEquals(Assert.java:542)
	at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathCount(AbstractAppSchemaTestSupport.java:372)
	at org.geoserver.test.PagingTest.testGetFeatureWithFilter(PagingTest.java:428)
Reverting this recent gs-app-schema-test change does not fix:
GEOS-8724 In Progress Intermittent build failure in NamespacesWfsTest (#2870)
https://github.com/geoserver/geoserver/commit/75c76394a6249027b3fe27d6d3b8505ef331a69a
https://osgeo-org.atlassian.net/browse/GEOS-8724
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100083-sha1:62e6e97)
Atlassian logo
