[Geoserver-devel] [JIRA] (GEOS-8744) Updating a SLD style using the API omits the <Stroke> section in Polygon/LineSymbolizer
Nathan Van der Auwera created an issue
GeoServer / BugGEOS-8744
Issue Type:
BugBug
Affects Versions:
2.13.0
Assignee:
Unassigned
Components:
REST, styling
Created:
14/May/18 7:07 PM
Priority:
MediumMedium
Reporter:
When attempting to update an SLD using the REST API
on the endpoint PUT /styles/
{name}
with the following content
      &lt;?xml version="1.0" encoding="UTF-8"?&gt;
      &lt;StyledLayerDescriptor version="1.0.0"
        xsi:schemaLocation="http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd"
        xmlns="http://www.opengis.net/sld" xmlns:ogc="http://www.opengis.net/ogc"
        xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"&gt;
        &lt;NamedLayer&gt;
          &lt;Name&gt;Communities&lt;/Name&gt;
          &lt;UserStyle&gt;
            &lt;Title&gt;A violet polygon style&lt;/Title&gt;
            &lt;FeatureTypeStyle&gt;
              &lt;Rule&gt;
                &lt;Title&gt;Gemeentes&lt;/Title&gt;
                &lt;PolygonSymbolizer&gt;
                  &lt;Fill&gt;
                    &lt;CssParameter name="fill"&gt;#3300ff
                    &lt;/CssParameter&gt;
                  &lt;/Fill&gt;
                  &lt;Stroke&gt;
                    &lt;CssParameter name="stroke"&gt;#000000&lt;/CssParameter&gt;
                    &lt;CssParameter name="stroke-width"&gt;1&lt;/CssParameter&gt;
                  &lt;/Stroke&gt;
                &lt;/PolygonSymbolizer&gt;
              &lt;/Rule&gt;
            &lt;/FeatureTypeStyle&gt;
          &lt;/UserStyle&gt;
        &lt;/NamedLayer&gt;
      &lt;/StyledLayerDescriptor&gt;
the <Stroke> part is then emptied (just an empty tag). I tried this with a PolygonSymbolizer and a LineSymbolizer and the result is the same for both. Weirdly though the Fill is retained correctly.
For completeness, the above sld is converted to the following:
&lt;?xml version="1.0" encoding="UTF-8"?&gt;&lt;sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld" xmlns:sld="http://www.opengis.net/sld" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" version="1.0.0"&gt;
  &lt;sld:NamedLayer&gt;
    &lt;sld:Name&gt;Default Styler&lt;/sld:Name&gt;
    &lt;sld:UserStyle&gt;
      &lt;sld:Title&gt;A violet polygon style&lt;/sld:Title&gt;
      &lt;sld:FeatureTypeStyle&gt;
        &lt;sld:Name&gt;name&lt;/sld:Name&gt;
        &lt;sld:Rule&gt;
          &lt;sld:Title&gt;Gemeentes&lt;/sld:Title&gt;
          &lt;sld:PolygonSymbolizer&gt;
            &lt;sld:Fill&gt;
              &lt;sld:CssParameter name="fill"&gt;#3300ff&lt;/sld:CssParameter&gt;
            &lt;/sld:Fill&gt;
            &lt;sld:Stroke/&gt;
          &lt;/sld:PolygonSymbolizer&gt;
        &lt;/sld:Rule&gt;
      &lt;/sld:FeatureTypeStyle&gt;
    &lt;/sld:UserStyle&gt;
  &lt;/sld:NamedLayer&gt;
&lt;/sld:StyledLayerDescriptor&gt;
(I have not yet tried to create a new style using the API using the new version
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100084-sha1:841e6db)
Atlassian logo
