I’m using geoserver rest api to control my server.
Recently I encountered problem while creating ImageMosaic.
Running the following command (the file is attached), produces a coverage with inappropriate parameters types:
curl -v -u admin:geoserver -XPUT -H "Content-type:application/zip" -T base_coverage.zip http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/dems59/file.imagemosaic
Fetching the coverage properties, gives me the following XML:
curl -v -u admin:geoserver -XGET http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/dems59/coverages/dems59
<coverage>
<name>dems59</name>
<nativeName>dems59</nativeName>
<namespace>
<name>cite</name>
<atom:link xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver/rest/namespaces/cite.xml" type="application/xml"/>
</namespace>
<title>dems59</title>
<description>Generated from ImageMosaic</description>
<keywords>
<string>dems59</string>
<string>WCS</string>
<string>ImageMosaic</string>
</keywords>
<nativeCRS>GEOGCS[&quot;WGS 84&quot;,
DATUM[&quot;World Geodetic System 1984&quot;,
SPHEROID[&quot;WGS 84&quot;, 6378137.0, 298.257223563, AUTHORITY[&quot;EPSG&quot;,&quot;7030&quot;]],
AUTHORITY[&quot;EPSG&quot;,&quot;6326&quot;]],
PRIMEM[&quot;Greenwich&quot;, 0.0, AUTHORITY[&quot;EPSG&quot;,&quot;8901&quot;]],
UNIT[&quot;degree&quot;, 0.017453292519943295],
AXIS[&quot;Geodetic longitude&quot;, EAST],
AXIS[&quot;Geodetic latitude&quot;, NORTH],
AUTHORITY[&quot;EPSG&quot;,&quot;4326&quot;]]</nativeCRS>
<srs>EPSG:4326</srs>
<nativeBoundingBox>
<minx>-180.0</minx>
<maxx>180.0</maxx>
<miny>-79.0</miny>
<maxy>78.0</maxy>
<crs>EPSG:4326</crs>
</nativeBoundingBox>
<latLonBoundingBox>
<minx>-180.0</minx>
<maxx>180.0</maxx>
<miny>-79.0</miny>
<maxy>78.0</maxy>
</latLonBoundingBox>
<projectionPolicy>REPROJECT_TO_DECLARED</projectionPolicy>
<enabled>true</enabled>
<metadata>
<entry key="dirName">dems59_null</entry>
</metadata>
<store class="coverageStore">
<name>cite:dems59</name>
<atom:link xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/dems59.xml" type="application/xml"/>
</store>
<nativeFormat>ImageMosaic</nativeFormat>
<grid dimension="2">
<range>
<low>0 0</low>
<high>288 157</high>
</range>
<transform>
<scaleX>1.25</scaleX>
<scaleY>-1.0</scaleY>
<shearX>0.0</shearX>
<shearY>0.0</shearY>
<translateX>-179.375</translateX>
<translateY>77.5</translateY>
</transform>
</grid>
<supportedFormats>
<string>GeoPackage (mosaic)</string>
<string>GEOTIFF</string>
<string>Gtopo30</string>
<string>GIF</string>
<string>PNG</string>
<string>JPEG</string>
<string>TIFF</string>
<string>ArcGrid</string>
</supportedFormats>
<interpolationMethods>
<string>nearest neighbor</string>
<string>bilinear</string>
<string>bicubic</string>
</interpolationMethods>
<defaultInterpolationMethod>nearest neighbor</defaultInterpolationMethod>
<dimensions>
<coverageDimension>
<name>GRAY_INDEX</name>
<description>GridSampleDimension[-Infinity,Infinity]</description>
<range>
<min>-inf</min>
<max>inf</max>
</range>
<nullValues>
<double>9999.0</double>
</nullValues>
<dimensionType>
<name>REAL_32BITS</name>
</dimensionType>
</coverageDimension>
</dimensions>
<requestSRS>
<string>EPSG:4326</string>
</requestSRS>
<responseSRS>
</responseSRS>
<parameters>
<entry>
<string>BackgroundValues</string>
<string></string>
</entry>
<entry>
<string>OVERVIEW_POLICY</string>
<string>QUALITY</string>
</entry>
<entry>
<string>MergeBehavior</string>
<string>FLAT</string>
</entry>
<entry>
<string>AllowMultithreading</string>
<string>false</string>
</entry>
<entry>
<string>MaxAllowedTiles</string>
<string>-1</string>
</entry>
<entry>
<string>ExcessGranuleRemoval</string>
<string>NONE</string>
</entry>
<entry>
<string>OutputTransparentColor</string>
<string></string>
</entry>
<entry>
<string>USE_JAI_IMAGEREAD</string>
<string>true</string>
</entry>
<entry>
<string>Bands</string>
<string></string>
</entry>
<entry>
<string>Filter</string>
<string></string>
</entry>
<entry>
<string>InputTransparentColor</string>
<string></string>
</entry>
<entry>
<string>SUGGESTED_TILE_SIZE</string>
<string>512,512</string>
</entry>
<entry>
<string>Accurate resolution computation</string>
</entry>
<entry>
<string>SORTING</string>
<string></string>
</entry>
<entry>
<string>FootprintBehavior</string>
<string>None</string>
</entry>
</parameters>
<nativeCoverageName>dems59</nativeCoverageName
You can see, for example, that USE_JAI_IMAGEREAD parameter type is defined as ‘string’ which is wrong (should be ‘boolean’).
<entry>
</entry>
This becomes a real trouble when I’m trying to use the REST api to UPDATE coverage parameters. Using the given (wrong) type, doesn’t update the parameter.
This makes it impossible to update those parameters via the api, unless you guess the correct type (which is impossible to do while using this ability in code).
On the other hand, when the coverage is created via Geoserver control GUI, the parameters type are defined correctly:
curl -v -u admin:geoserver -XGET http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/dems60/coverages/dems60
[^base_coverage.zip]
<coverage>
<name>dems60</name>
<nativeName>dems60</nativeName>
<namespace>
<name>cite</name>
</namespace>
<title>dems60</title>
<keywords>
<string>dems60</string>
</keywords>
<nativeBoundingBox>
<minx>34.99986111111111</minx>
<maxx>36.000138888888884</maxx>
<miny>30.999861111111112</miny>
<maxy>32.00013888888889</maxy>
<latLonBoundingBox>
<metadata>
<entry key="dirName">dems60_dems60</entry>
</metadata>
<name>cite:dems60</name>
<atom:link xmlns:atom="http://www.w3.org/2005/Atom" rel="alternate" href="http://localhost:8080/geoserver/rest/workspaces/cite/coveragestores/dems60.xml" type="application/xml"/>
</store>
<range>
<low>0 0</low>
<high>3600 3601</high>
</range>
<transform>
<scaleX>2.777777777777778E-4</scaleX>
<scaleY>-2.777777777777778E-4</scaleY>
<translateX>35.0</translateX>
<translateY>32.0</translateY>
</transform>
</grid>
<supportedFormats>
</supportedFormats>
<dimensions>
<coverageDimension>
<range>
<min>-inf</min>
<max>inf</max>
</range>
<nullValues>
<double>-32767.0</double>
</nullValues>
<dimensionType>
<name>SIGNED_16BITS</name>
</dimensionType>
</dimensions>
<requestSRS>
</requestSRS>
<responseSRS>
</responseSRS>
<parameters>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
</entry>
<entry>
<boolean>false</boolean>
</entry>
<entry>
<int>-1</int>
</entry>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
<boolean>true</boolean>
</entry>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
<null/>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<null/>
</entry>
<entry>
</entry>
</parameters>
<nativeCoverageName>dems60</nativeCoverageName>
