[Geoserver-devel] [JIRA] (GEOS-8747) Startup failure with NoClassDefFoundError for Log4jLoggerFactory
Ben Caradoc-Davies created an issue
GeoServer / BugGEOS-8747
Issue Type:
BugBug
Affects Versions:
2.14-beta
Assignee:
Unassigned
Created:
16/May/18 1:53 AM
Environment:
$ java -version
openjdk version “1.8.0_171”
OpenJDK Runtime Environment (build 1.8.0_171-8u171-b11-1-b11)
OpenJDK 64-Bit Server VM (build 25.171-b11, mixed mode)
Same failure also seen with OpenJDK 9 and 10.
Priority:
MediumMedium
Reporter:
Ben Caradoc-Davies
With geoserver-2.14-SNAPSHOT-bin.zip built from master at 08c15fbc31f6 ,Jetty starts but accessing GeoServer at http://localhost:8080/geoserver/web/ results in a 404 Not Found. Failure occurs with OpenJDK 8, 9, and 10.
Notable:
SLF4J: Detected both log4j-over-slf4j.jar AND slf4j-log4j12.jar on the class path, preempting StackOverflowError.
SLF4J: See also http://www.slf4j.org/codes.html#log4jDelegationLoop for more details.
{format}
java.lang.NoClassDefFoundError: Could not initialize class org.apache.log4j.Log4jLoggerFactory{format}
Full console:
$ bin/startup.sh
GEOSERVER_HOME environment variable not found, using current
directory.  If not set then running this script from other
directories will not work in the future.
GEOSERVER DATA DIR is /home/ben/tmp/geoserver/geoserver-2.14-SNAPSHOT/data_dir
WARNING: Module not found [ssl]
2018-05-16 11:35:01.007:INFO::main: Logging initialized @121ms
2018-05-16 11:35:01.089:INFO:oejs.Server:main: jetty-9.2.13.v20150730
2018-05-16 11:35:01.098:INFO:oejdp.ScanningAppProvider:main: Deployment monitor [file:/home/ben/tmp/geoserver/geoserver-2.14-SNAPSHOT/webapps/] at interval 1
2018-05-16 11:35:01.503:INFO:oejw.StandardDescriptorProcessor:main: NO JSP Support for /geoserver, did not find org.eclipse.jetty.jsp.JettyJspServlet
2018-05-16 11:35:01.821:WARN:oejuc.AbstractLifeCycle:main: FAILED o.e.j.w.WebAppContext@anonymised.com{/geoserver,file:/home/ben/tmp/geoserver/geoserver-2.14-SNAPSHOT/webapps/geoserver/,STARTING}{/geoserver}: java.util.ServiceConfigurationError: javax.imageio.spi.ImageReaderSpi: Provider org.geotools.imageio.netcdf.NetCDFImageReaderSpi could not be instantiated
	at java.util.ServiceLoader.fail(ServiceLoader.java:232)
	at java.util.ServiceLoader.access$100(ServiceLoader.java:185)
	at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:384)
	at java.util.ServiceLoader$LazyIterator.next(ServiceLoader.java:404)
	at java.util.ServiceLoader$1.next(ServiceLoader.java:480)
	at javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:210)
	at javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:138)
	at javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:159)
	at javax.imageio.ImageIO.<clinit>(ImageIO.java:66)
	at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:190)
	at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
	at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:444)
	at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:791)
	at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:294)
	at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1349)
	at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1342)
	at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:741)
	at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:505)
	at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
	at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
	at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
	at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:498)
	at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:146)
	at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
	at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:440)
	at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
	at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
	at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:528)
	at org.eclipse.jetty.util.Scanner.scan(Scanner.java:391)
	at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
	at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
	at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:560)
	at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:235)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
	at org.eclipse.jetty.server.Server.start(Server.java:387)
	at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
	at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
	at org.eclipse.jetty.server.Server.doStart(Server.java:354)
	at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1255)
	at java.security.AccessController.doPrivileged(Native Method)
	at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:498)
	at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
	at org.eclipse.jetty.start.Main.start(Main.java:817)
	at org.eclipse.jetty.start.Main.main(Main.java:112)
Caused by:
	at org.apache.log4j.LogManager.getLogger(LogManager.java:42)
	at org.slf4j.impl.Log4jLoggerFactory.getLogger(Log4jLoggerFactory.java:64)
	at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:253)
	at org.slf4j.LoggerFactory.getLogger(LoggerFactory.java:265)
	at ucar.nc2.NetcdfFile.<clinit>(NetcdfFile.java:95)
	at org.geotools.imageio.netcdf.utilities.NetCDFUtilities.<clinit>(NetCDFUtilities.java:311)
	at org.geotools.imageio.netcdf.NetCDFImageReaderSpi.<clinit>(NetCDFImageReaderSpi.java:116)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:423)
	at java.lang.Class.newInstance(Class.java:442)
	at java.util.ServiceLoader$LazyIterator.nextService(ServiceLoader.java:380)
2018-05-16 11:35:01.822:WARN:oejd.DeploymentManager:main: Unable to reach node goal: started
Caused by:
2018-05-16 11:35:01.828:INFO:oejs.ServerConnector:main: Started ServerConnector@anonymised.com{HTTP/1.1}{0.0.0.0:8080}
2018-05-16 11:35:01.828:INFO:oejs.Server:main: Started @943ms
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100085-sha1:5dcb565)
Atlassian logo
