Startup of geoserver-2.13.0-bin.zip with Java 9 contains a handled NumberFormatException . Curiously, his does not affect Java 8 or Java 10.
Caught and handled this exception :
java.lang.NumberFormatException: For input string: ""
at java.base/java.lang.NumberFormatException.forInputString(NumberFormatException.java:65)
at java.base/java.lang.Integer.parseInt(Integer.java:662)
at java.base/java.lang.Integer.parseInt(Integer.java:770)
at com.sun.media.imageioimpl.common.ImageUtil.processOnRegistration(ImageUtil.java:1408)
at com.sun.media.imageioimpl.plugins.wbmp.WBMPImageWriterSpi.onRegistration(WBMPImageWriterSpi.java:106)
at java.desktop/javax.imageio.spi.SubRegistry.registerServiceProvider(ServiceRegistry.java:788)
at java.desktop/javax.imageio.spi.ServiceRegistry.registerServiceProvider(ServiceRegistry.java:330)
at java.desktop/javax.imageio.spi.IIORegistry.registerApplicationClasspathSpis(IIORegistry.java:212)
at java.desktop/javax.imageio.spi.IIORegistry.<init>(IIORegistry.java:136)
at java.desktop/javax.imageio.spi.IIORegistry.getDefaultInstance(IIORegistry.java:157)
at java.desktop/javax.imageio.ImageIO.<clinit>(ImageIO.java:66)
at org.geoserver.GeoserverInitStartupListener.contextInitialized(GeoserverInitStartupListener.java:190)
at org.eclipse.jetty.server.handler.ContextHandler.callContextInitialized(ContextHandler.java:800)
at org.eclipse.jetty.servlet.ServletContextHandler.callContextInitialized(ServletContextHandler.java:444)
at org.eclipse.jetty.server.handler.ContextHandler.startContext(ContextHandler.java:791)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:294)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1349)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1342)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:741)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:505)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:68)
at org.eclipse.jetty.deploy.bindings.StandardStarter.processBinding(StandardStarter.java:41)
at org.eclipse.jetty.deploy.AppLifeCycle.runBindings(AppLifeCycle.java:186)
at org.eclipse.jetty.deploy.DeploymentManager.requestAppGoal(DeploymentManager.java:498)
at org.eclipse.jetty.deploy.DeploymentManager.addApp(DeploymentManager.java:146)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.fileAdded(ScanningAppProvider.java:180)
at org.eclipse.jetty.deploy.providers.WebAppProvider.fileAdded(WebAppProvider.java:440)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider$1.fileAdded(ScanningAppProvider.java:64)
at org.eclipse.jetty.util.Scanner.reportAddition(Scanner.java:609)
at org.eclipse.jetty.util.Scanner.reportDifferences(Scanner.java:528)
at org.eclipse.jetty.util.Scanner.scan(Scanner.java:391)
at org.eclipse.jetty.util.Scanner.doStart(Scanner.java:313)
at org.eclipse.jetty.deploy.providers.ScanningAppProvider.doStart(ScanningAppProvider.java:150)
at org.eclipse.jetty.deploy.DeploymentManager.startAppProvider(DeploymentManager.java:560)
at org.eclipse.jetty.deploy.DeploymentManager.doStart(DeploymentManager.java:235)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:132)
at org.eclipse.jetty.server.Server.start(Server.java:387)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:114)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:61)
at org.eclipse.jetty.server.Server.doStart(Server.java:354)
at org.eclipse.jetty.xml.XmlConfiguration$1.run(XmlConfiguration.java:1255)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at org.eclipse.jetty.xml.XmlConfiguration.main(XmlConfiguration.java:1174)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.jetty.start.Main.invokeMain(Main.java:321)
at org.eclipse.jetty.start.Main.start(Main.java:817)
at org.eclipse.jetty.start.Main.main(Main.java:112)
