[Geoserver-devel] [JIRA] (GEOS-8753) GWC curl returns "Chunk [] is not a valid entry" message error when killing all jobs of all layers.
Simon Hofer created an issue
GeoServer / BugGEOS-8753
GWC curl returns “Chunk [] is not a valid entry” message error when killing all jobs of all layers.
Issue Type:
BugBug
Affects Versions:
2.13.0
Assignee:
Unassigned
Created:
20/May/18 9:28 AM
Environment:
Docker, Ubuntu, Jetty, Geoserver 2.13
Priority:
MediumMedium
Reporter:
Simon Hofer
When I run the following curl command according the documentation:
curl -v -u admin:geoserver -d "kill_all=all"  "http://localhost:8080/geoserver/gwc/rest/seed"
I get the following error message:
From the logs:
geoserver_1  | 20 May 07:21:05 ERROR [geoserver.rest] - Chunk [] is not a valid entry
geoserver_1  | java.lang.IllegalArgumentException: Chunk [] is not a valid entry
geoserver_1  | 	at com.google.common.base.Preconditions.checkArgument(Preconditions.java:148)
geoserver_1  | 	at com.google.common.base.Splitter$MapSplitter.split(Splitter.java:508)
geoserver_1  | 	at org.geowebcache.rest.service.SeedService.splitToMap(SeedService.java:254)
geoserver_1  | 	at org.geowebcache.rest.service.SeedService.handleKillAllThreads(SeedService.java:148)
geoserver_1  | 	at org.geowebcache.rest.controller.SeedController.doPost(SeedController.java:110)
It seems to me somehow related to the already solved problem GEOS-8474 Resolved .
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100085-sha1:2007996)
Atlassian logo
