PostScriptTransformTest calls FileUtils.deleteQuietly on the system temporary directory (/tmp on Linux), causing its recursive deletion (as far as permissions allow), and all manner of havoc. In particular, this also deletes /tmp/Geotools , causing failure of any concurrently running test trying to resolve an EPSG code, not to mention the failure of any concurrently running test that stores data in /tmp .
In setUp :
https://github.com/geoserver/geoserver/blob/master/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/PostScriptTransformTest.java#L22
dd = new GeoServerDataDirectory(FileUtils.getTempDirectory());
FileUtils.getTempDirectory() is not a temporary directory, it is the temporary directory. Later, in teardown :
https://github.com/geoserver/geoserver/blob/master/src/extension/importer/rest/src/test/java/org/geoserver/importer/rest/PostScriptTransformTest.java#L36
File dir = dd.getRoot().dir();
FileUtils.deleteQuietly(dir);
