[Geoserver-devel] [JIRA] (GEOS-8802) CoverageViewTest intermittent failures
Ben Caradoc-Davies created an issue
GeoServer / BugGEOS-8802
Issue Type:
BugBug
Affects Versions:
2.14-beta, 2.13.1
Assignee:
Unassigned
gt-epsg-hsql-imagemosaicformat-getreader-printstacktrace.patch, hsqldb-2.3.0.jar
Components:
Main
Created:
25/Jun/18 4:31 AM
Priority:
MediumMedium
Reporter:
Ben Caradoc-Davies
tl;dr: boot Linux with maxcpus=2 to reproduce this failure in about one in four Maven builds.
In hundreds of scripted builds, many other failures were also seen, all related to EPSG code lookup. The core finding of this investigation is an NPE at org.hsqldb.Database.connect(Database.java:384). I suspect a synchronisation problem with EPSG database access.
The super-long version:
  • Attached patch for gt-epsg-hsql changes ImageMosaicReader.getReader to print a stack trace rather than swallowing exceptions.
  • Attached hsqldb-2.3.0.jar has been rebuild with debugging information (needed Oracle JDK 7 to build).
  • Linux booted with maxcpus=2.
  • Building gs-main with mvn -o clean install.
After several builds the following is seen:
Running org.geoserver.catalog.CoverageViewTest
source = /home/ben/geoserver/src with spaces/geoserver/src/main/./target/default5111977893338354336data/s2reduced
hints = Hints:
  REPOSITORY       = org.geoserver.catalog.CatalogRepository@anonymised.com
  EXECUTOR_SERVICE = java.util.concurrent.ThreadPoolExecutor@anonymised.com[Running, pool size = 0, active threads = 0, queued tasks = 0, completed tasks = 0]
System defaults:
  GRID_COVERAGE_FACTORY            = GridCoverageFactory
    TILE_ENCODING                  = null
  FORCE_LONGITUDE_FIRST_AXIS_ORDER = true
  COMPARISON_TOLERANCE             = 1.0E-7
  FILTER_FACTORY                   = FilterFactoryImpl
  FORCE_AXIS_ORDER_HONORING        = http
  STYLE_FACTORY                    = StyleFactoryImpl
  LENIENT_DATUM_SHIFT              = true
  FEATURE_FACTORY                  = org.geotools.feature.LenientFeatureFactoryImpl@anonymised.com
org.geotools.data.DataSourceException
	at org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:513)
	at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:566)
	at org.geotools.gce.imagemosaic.ImageMosaicFormat.getReader(ImageMosaicFormat.java:108)
	at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1524)
	at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1444)
	at org.geoserver.catalog.CoverageView.buildCoverageInfo(CoverageView.java:387)
	at org.geoserver.catalog.CoverageView.createCoverageInfo(CoverageView.java:398)
	at org.geoserver.catalog.CoverageViewTest.buildHeterogeneousResolutionView(CoverageViewTest.java:698)
	at org.geoserver.catalog.CoverageViewTest.testHeterogeneousViewIntersectionEnvelope(CoverageViewTest.java:458)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
	at java.lang.reflect.Method.invoke(Method.java:498)
Caused by: org.geotools.data.DataSourceException
	at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:721)
	at org.geotools.gce.imagemosaic.ImageMosaicReader.<init>(ImageMosaicReader.java:511)
	... 42 more
Caused by: java.lang.NullPointerException
	at org.hsqldb.DatabaseManager.newSession(DatabaseManager.java:163)
	at org.hsqldb.jdbc.JDBCConnection.<init>(JDBCConnection.java:3593)
	at org.hsqldb.jdbc.JDBCDriver.getConnection(JDBCDriver.java:312)
	at org.hsqldb.jdbc.JDBCDataSource.getConnection(JDBCDataSource.java:192)
	at org.hsqldb.jdbc.JDBCDataSource.getConnection(JDBCDataSource.java:151)
	at org.geotools.referencing.factory.epsg.DirectEpsgFactory.getConnection(DirectEpsgFactory.java:3543)
	at org.geotools.referencing.factory.epsg.DirectEpsgFactory.prepareStatement(DirectEpsgFactory.java:807)
	at org.geotools.referencing.factory.epsg.DirectEpsgFactory.createCoordinateReferenceSystem(DirectEpsgFactory.java:2067)
	at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:732)
	at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:780)
	at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:625)
	at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:629)
	at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:636)
	at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:177)
	at org.geotools.referencing.CRS.decode(CRS.java:517)
	at org.geotools.gce.imagemosaic.Utils.decodeSrs(Utils.java:930)
	at org.geotools.gce.imagemosaic.Utils.loadMosaicProperties(Utils.java:873)
	at org.geotools.gce.imagemosaic.Utils.loadMosaicProperties(Utils.java:560)
	at org.geotools.gce.imagemosaic.ImageMosaicReader.initReaderFromURL(ImageMosaicReader.java:620)
	... 43 more
Tests run: 15, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 4.276 sec <<< FAILURE!
testHeterogeneousViewIntersectionEnvelope(org.geoserver.catalog.CoverageViewTest)  Time elapsed: 51 sec  <<< ERROR!
java.io.IOException: Failed to create reader from file:/home/ben/geoserver/src%20with%20spaces/geoserver/src/main/./target/default5111977893338354336data/s2reduced/ and hints Hints:
System defaults:
	at org.geoserver.catalog.ResourcePool.getGridCoverageReader(ResourcePool.java:1526)
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100087-sha1:2813e6b)
Atlassian logo
