[Geoserver-devel] [JIRA] (GEOS-8855) Problems connecting to a WFS server from other vendor
javier urien created an issue
GeoServer / StoryGEOS-8855
Issue Type:
StoryStory
Assignee:
Unassigned
Created:
23/Jul/18 8:03 PM
Environment:
GeoServer 2.13
Priority:
MediumMedium
Reporter:
javier urien
I am trying to connect GeoServer with a secondary WFS server from another vendor (Luciad, OGCServices).
I created datastore and it got accepted by GeoServer.
I went to create a Layer and when I try to publish I get the following error:
This is what I get using GeoServer 2.13
Caused by: java.lang.RuntimeException: org.geotools.data.DataSourceException: No XSDElementDeclaration found for {http://www.opengis.net/wfs}cities
	at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:358)
	at org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:325)
	at org.geotools.data.store.ContentDataStore.getSchema(ContentDataStore.java:345)
	at org.geoserver.feature.retype.RetypingDataStore.updateMap(RetypingDataStore.java:214)
	at org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:170)
	at org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:327)
	at org.geoserver.feature.retype.RetypingDataStore.getFeatureSource(RetypingDataStore.java:49)
	at org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:376)
	at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:401)
	... 112 more
Caused by: org.geotools.data.DataSourceException: No XSDElementDeclaration found for {http://www.opengis.net/wfs}cities
	at org.geotools.data.wfs.internal.parsers.EmfAppSchemaParser.parseFeatureType(EmfAppSchemaParser.java:306)
	at org.geotools.data.wfs.internal.parsers.EmfAppSchemaParser.parse(EmfAppSchemaParser.java:217)
	at org.geotools.data.wfs.internal.DescribeFeatureTypeResponse.<init>(DescribeFeatureTypeResponse.java:65)
	at org.geotools.data.wfs.internal.parsers.DescribeFeatureTypeResponseFactory.createResponse(DescribeFeatureTypeResponseFactory.java:63)
	at org.geotools.data.wfs.internal.WFSRequest.createResponse(WFSRequest.java:220)
	at org.geotools.data.wfs.internal.WFSRequest.createResponse(WFSRequest.java:38)
	at org.geotools.data.ows.AbstractOpenWebService.internalIssueRequest(AbstractOpenWebService.java:445)
	at org.geotools.data.wfs.internal.WFSClient.internalIssueRequest(WFSClient.java:298)
	at org.geotools.data.wfs.internal.WFSClient.issueRequest(WFSClient.java:360)
	at org.geotools.data.wfs.WFSDataStore.getRemoteFeatureType(WFSDataStore.java:210)
	at org.geotools.data.wfs.WFSDataStore.getRemoteSimpleFeatureType(WFSDataStore.java:264)
	at org.geotools.data.wfs.WFSFeatureSource.buildFeatureType(WFSFeatureSource.java:348)
	at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:356)
	... 120 more
And this is what I get from 2.9-SNAPSHOT (shipped with GeoNode 2.6.3)
Caused by: java.lang.RuntimeException: org.opengis.referencing.NoSuchAuthorityCodeException: Authority "OGC" is unknown or doesn't match the supplied hints. Maybe it is defined in an unreachable JAR file?
	at org.geotools.data.wfs.internal.v1_x.FeatureTypeInfoImpl.getCRS(FeatureTypeInfoImpl.java:130)
	at org.geotools.data.wfs.internal.DescribeFeatureTypeResponse.<init>(DescribeFeatureTypeResponse.java:51)
	at org.geotools.data.wfs.internal.parsers.DescribeFeatureTypeResponseFactory.createResponse(DescribeFeatureTypeResponseFactory.java:59)
	at org.geotools.data.wfs.internal.WFSClient.internalIssueRequest(WFSClient.java:288)
	at org.geotools.data.wfs.internal.WFSClient.issueRequest(WFSClient.java:350)
	at org.geotools.data.wfs.WFSDataStore.getRemoteFeatureType(WFSDataStore.java:214)
	at org.geotools.data.wfs.WFSDataStore.getRemoteSimpleFeatureType(WFSDataStore.java:268)
	at org.geotools.data.store.ContentFeatureSource.getAbsoluteSchema(ContentFeatureSource.java:343)
	at org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:312)
	at org.geotools.data.store.ContentFeatureSource.getSchema(ContentFeatureSource.java:112)
	at org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:351)
	at org.geoserver.catalog.CatalogBuilder.buildFeatureType(CatalogBuilder.java:333)
	at org.geoserver.web.data.layer.NewLayerPage.buildLayerInfo(NewLayerPage.java:359)
	... 120 more
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: Authority "OGC" is unknown or doesn't match the supplied hints. Maybe it is defined in an unreachable JAR file?
	at org.geotools.referencing.factory.ManyAuthoritiesFactory.noSuchAuthority(ManyAuthoritiesFactory.java:489)
	at org.geotools.referencing.factory.ManyAuthoritiesFactory.getAuthorityFactory(ManyAuthoritiesFactory.java:467)
	at org.geotools.referencing.factory.ManyAuthoritiesFactory.getCRSAuthorityFactory(ManyAuthoritiesFactory.java:548)
	at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
	at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:802)
	at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
	at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
	at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
	at org.geotools.referencing.CRS.decode(CRS.java:525)
	at org.geotools.data.wfs.internal.v1_x.FeatureTypeInfoImpl.getCRS(FeatureTypeInfoImpl.java:128)
	... 136 more
Caused by: org.geotools.factory.FactoryNotFoundException: No factory of kind "CRSAuthorityFactory" found.
	at org.geotools.factory.FactoryRegistry.getServiceProvider(FactoryRegistry.java:375)
	at org.geotools.factory.FactoryCreator.getServiceProvider(FactoryCreator.java:145)
	at org.geotools.referencing.ReferencingFactoryFinder.getAuthorityFactory(ReferencingFactoryFinder.java:220)
	at org.geotools.referencing.ReferencingFactoryFinder.getCRSAuthorityFactory(ReferencingFactoryFinder.java:440)
	at org.geotools.referencing.factory.AllAuthoritiesFactory.fromFactoryRegistry(AllAuthoritiesFactory.java:118)
	at org.geotools.referencing.factory.ManyAuthoritiesFactory.getAuthorityFactory(ManyAuthoritiesFactory.java:452)
	... 146 more
Please, I am at a loss to where start working and I have to integrate these two products.
Thank you very much!
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100090-sha1:16977f0)
Atlassian logo
