[Geoserver-devel] [JIRA] (GEOS-8869) Cannot set default style using layer PUT
Torben Barsballe created an issue
GeoServer / BugGEOS-8869
Issue Type:
BugBug
Assignee:
Unassigned
Created:
01/Aug/18 9:19 PM
Priority:
MediumMedium
Reporter:
Torben Barsballe
When doing a PUT to localhost:8080/geoserver/rest/layers/tiger:poi with the contents {"layer":{"name":"poi","defaultStyle":{"name":"capitals"}}}, the defaultStyle does not get updated.
This only affects JSON PUT, XML works fine.
This also only occurs when the Importer extension is installed. The issue appears to be being caused because ImportLayerJSONMessageConverter is being used instead of XStreamJSONMessageConverter.
The constraints on the Importer converter need to be tightened.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100090-sha1:e01264c)
Atlassian logo
