[Geoserver-devel] [JIRA] (GEOS-8885) YSLD styling breaks Google Earth KML Output formats
Jody Garnett created an issue
GeoServer / BugGEOS-8885
Issue Type:
BugBug
Affects Versions:
2.12.4
Assignee:
Unassigned
Components:
Google Earth KML Output, YSLD
Created:
10/Aug/18 7:39 PM
Priority:
MediumMedium
Reporter:
Jody Garnett
YSLD creates styling object with only the user supplied values. Here is an example where fill-color is provided:
title: color-green
symbolizers:
 - line:
    stroke-width: 2.0
    stroke-color: '#008000'
- text:
    label: ${LineNumber}
    font-size: 8
    font-family: Arial Black
    font-style: normal
    fill-color: Black
The KML Output formats were designed and tested with SLD 1.0 in mind (and assume the parser will fill in default values for anything not supplied by the user).
As an example PlacemarkStyleDecorator assumes fill opacity is always defined:
            if (fill != null) {
                Double opacity = fill.getOpacity().evaluate(feature, Double.class);
                if (opacity == null || Double.isNaN(opacity)) {
                    opacity = 1.0;
                Color color = fill.getColor().evaluate(feature, Color.class);
                ls.setColor(colorToHex(color, opacity));
            } else {
                ls.setColor("ffffffff");
This code fails with a style produced by YSLD:
Caused by: java.lang.NullPointerException
	at org.geoserver.kml.decorator.PlacemarkStyleDecoratorFactory$PlacemarkStyleDecorator.setLabelStyle(PlacemarkStyleDecoratorFactory.java:290)
	at org.geoserver.kml.decorator.PlacemarkStyleDecoratorFactory$PlacemarkStyleDecorator.decorate(PlacemarkStyleDecoratorFactory.java:115)
	at org.geoserver.kml.sequence.FeatureSequenceFactory$FeatureGenerator.next(FeatureSequenceFactory.java:137)
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100090-sha1:88b65a0)
Atlassian logo
