[Geoserver-devel] [JIRA] (GEOS-8892) coverageName ignored when creating an external ImageMosaic through REST API
Ilya Atkin - NOAA Affiliate created an issue
GeoServer / BugGEOS-8892
Issue Type:
BugBug
Affects Versions:
2.13.1
Assignee:
Unassigned
Components:
REST
Created:
14/Aug/18 4:34 PM
Environment:
CentOS 7 with Oracle JRE 1.8.0
Priority:
MediumMedium
Reporter:
The coverageName parameter is ignored when creating an external ImageMosaic through the REST API. The name of the resulting layer is set to the name of the enclosing directory. I am specifically working with database backed ImageMosaics, so I am not sure if this is also an issue with shapefile backed mosaics. The same URL with external.imagemosaic substituted with external.geotiff for instance works as expected. I am setting “content-type” to “text/plain” and “accept” to “application/xml” in my requests.
Example,
PUT /geoserver/rest/workspaces/ws/coveragestores/mosaic/external.imagemosaic?coverageName=layer
(data) /data/mosaic
results in a CoverageStore named “mosaic” and a layer named “mosaic” rather than a layer named “layer”
PUT /geoserver/rest/workspaces/ws/coveragestores/mosaic/external.geotiff?coverageName=layer
(data) /data/mosaic/image1.tiff
results in a CoverageStore named “mosaic” and a layer named "layer as expected.
Add Comment
Add Comment
Get Jira notifications on your phone! Download the Jira Cloud app for Android or iOS
This message was sent by Atlassian Jira (v1001.0.0-SNAPSHOT#100090-sha1:31c7d2d)
Atlassian logo
