doc/en/api/1.0.0/structuredcoverages.yaml
45- "maxOccurs": 1,
46- "nillable": true,
47: "binding": "com.vividsolutions.jts.geom.MultiPolygon"
48- },
49- {
83- <maxOccurs>1</maxOccurs>
84- <nillable>true</nillable>
85: <binding>com.vividsolutions.jts.geom.MultiPolygon</binding>
86- </Attribute>
87- <Attribute>
595- <maxOccurs>1</maxOccurs>
596- <nillable>true</nillable>
597: <binding>com.vividsolutions.jts.geom.MultiPolygon</binding>
598- </Attribute>
599- <Attribute>
doc/en/api/1.0.0/featuretypes.yaml
428- "maxOccurs": 1,
429- "nillable": true,
430: "binding": "com.vividsolutions.jts.geom.Point"
431- },
432- {
547- <maxOccurs>1</maxOccurs>
548- <nillable>true</nillable>
549: <binding>com.vividsolutions.jts.geom.Point</binding>
550- </attribute>
551- <attribute>
800- "maxOccurs": 1,
801- "nillable": true,
802: "binding": "com.vividsolutions.jts.geom.Point"
803- },
804- {
919- <maxOccurs>1</maxOccurs>
920- <nillable>true</nillable>
921: <binding>com.vividsolutions.jts.geom.Point</binding>
922- </attribute>
923- <attribute>
1318- "maxOccurs": 1,
1319- "nillable": true,
1320: "binding": "com.vividsolutions.jts.geom.Point"
1321- },
1322- {
doc/en/user/source/extensions/importer/rest_reference.rst
721- {
722- name: "the_geom",
723: binding: "com.vividsolutions.jts.geom.MultiPoint"
724- },
725- {
doc/en/user/source/extensions/importer/rest_examples.rst
195- {
196- "name": "the_geom",
197: "binding": "com.vividsolutions.jts.geom.MultiPoint"
198- },
199- {
doc/en/user/source/rest/stores.rst
310- <attribute>
311- <name>the_geom</name>
312: <binding>com.vividsolutions.jts.geom.Point</binding>
313- </attribute>
314- <attribute>
doc/en/user/source/rest/imagemosaic.rst
84- <maxOccurs>1</maxOccurs>
85- <nillable>true</nillable>
86: <binding>com.vividsolutions.jts.geom.Polygon</binding>
87- </Attribute>
88- <Attribute>
doc/en/user/source/community/scripting/hooks.rst
115-.. code-block:: groovy
116-
117: import com.vividsolutions.jts.geom.Geometry
118-
119- title = 'Buffer'
138-
139- from geoserver.wps import process
140: from com.vividsolutions.jts.geom import Geometry
141-
142- @process(
